Question about Bosch 24 in. SHU43 Built-in Dishwasher
Diswasher wont fill
Everytime we need to turn off hot water, then the dishwater wont fill; the engine works but water doesnt get in
Any thoughts??
  • Anonymous Mar 23, 2014
    Dishwater does not fill with water
    Problem Solver:
  • 8 Answers
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Posted on Apr 25, 2008
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
Problem is put the dishwater on ,doesnt seem to be enough water on the cycle ,dishwater goes through the whole cycle even drys, but has some water lying at the bottom at the end .Some said it might be a...
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is betting to the valve, the timer might ba faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
If you feel that there is water not being pumped out, remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 18, 2011 | Indesit Dishwashers
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
I have a Dishlex Global 500 dishwasher (DX500lWW*b). Woke up the other night to find water all over my kitchen floor. The hot water hose connector to the hot water tap split (bursted). The dishwater was...
I found this
"Hi - answer I was given by Electrolux Help was: pull machine out from under bench onto old towel, tip GENTLY onto left hand side (your left as you face the front of the machine) after it has drained, stand up gently, put back & turn on. Apparently it is the overflow trough reading as full ('oF' Overflow). Then run through some dishwasher descaler or Finish dishwasher cleaner. Worked for me."
http://www.howtomendit.com/answers.php?id=79783
Oct 05, 2009 | Dishwashers
Diswasher not heating water
check your connections under the sink. A dishwasher (unless it is a commercial one) is not built to heat water the water is supplied via the water heater via the sink angle stop. The dishwasher does however have a heating element inside used to dry the dishes. I would check the hot water side of the sink where the dishwasher is connected to see if the problem could be in that area. Check your setting on the machine. Good Luck on your repairs
Dave
Sep 15, 2009 | Dishwashers
I have a neff dishwasher that is maybe 5 years old. im pretty sure there is nothing wrong with it as it was working perfectly fine before i had a plumbing problem a few days ago. after the plumbing problem...
Look for the connection from the valve to the inlet of diswasher. Check the hot water valve to be on. It is probably closed when anyone working on the plumping. Good luck.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Water not hot nor warm
When you run the hot water at the kitchen sink until it is hot and start a cycle on your dishwasher, is water hot when you open the door after it stops filling?
If no, the diswasher is connected to the cold water line, not the hot water line. The water temerature entering should be a minimum of 120 degrees but no hotter than 140 degrees.
If the water going in is hot, but it cools down after each filling then the heating element has failed and needs to be replaced. When the heating element fails, the dishes, especially the glassware will be foggy and still dirty.
Please reply with what you find. Good Luck!
Mar 30, 2009 | Dishwashers
Dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
May 04, 2007 | Maytag 24 in. MDB7751AWS Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
366 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
