Question about Whirlpool Duet GHW9150P Front Load Washer
Not starting My washer doesn't star it shows a message on the time diplay window that says ld and the a F.
  • Anonymous Apr 19, 2008
    control locked on washer can start
  • 5,911 Answers
"Fdl" is a door lock error code. This could be an indication of a loose door latch, a defective door latch mechanism, or a problem with the wiring harness from the Central Control Unit (CCU) to the door latch.
At the control panel select:
DRAIN SPIN,
NO SPIN,
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" should be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit. If diagnostics fails (the door latch will attempt to lock 6 times before generating a fault code), UNPLUG the washer and remove the top cover. Remove the three screws holding the top panel in place on the back of the washer. Once the screws are removed, the panel slides back then off. Inspect the wiring harness to the door latch and make sure the latch is not loose (mounted to the right-hand side of the door frame).
NOTE: You can stop diagnostics at any time by pressing the PAUSE/CANCEL button.
If you determine the door latch is not loose, and you've checked all the connections from the CCU to the latch, you may have to replace the door latch assembly. Go to searspartsdirect.com and type in your COMPLETE model number in the Search menu. The part will be found under the "Door and Latch Parts" heading as item number 7. To replace, follow these instructions:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and run diagnostics again.
Good luck to you and let me know if you have any further questions.
Posted on Apr 14, 2008
Electrolux ewt 10410W
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Dec 27, 2013 | Washing Machines
Machine stops during cycle
"LD" stands for long drain meaning that the pump could be bad or that it just needs to be cleaned out.
Jul 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer is diplaying Ld and won't restart
Ld stands for long drain.
Here is what the manufacture says about that error, my comments will follow.
LONG DRAIN If the drain time exceeds eight minutes, Ld will be displayed, the water valves will turn off, and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be cleared and the machine will turn off after a maximum of eight minutes. Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the drain pump filter for foreign objects, and also make sure the hose from the tub to the pump is not plugged or kinked.
4. Check the electrical connections at the pump and make sure the pump is running.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments -----> This error is usually due to something getting stuck in the drain pump or drain hose, typically after washing a rug with a rubber backing that has come off or small articles like baby socks that were not put into a garment bag prior to washing.
To clean out the pump the machine would need disassembled and is best done by a service professional unless you are up for a good challenge.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Message LD on washer
L D code meanning long drain. lint causing the problem . and restricting the pump inlet .. remove pump and clean out .. ****
Dec 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal De
