1995 Toyota Camry Logo
Posted on Jun 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unknown light indicator in the dashboard
Not sure of light indicator on the left side of the fuel gauge on the dashboard of 1995 toyota camry. It has a picture of a little car with both tail light flashing symbol. I test both left and right signal, break, turn on light. All the light work just fine. What does the warning indicates?
Anonymous
Level 3:
  • Master 4,793 Answers
  • Posted on Jun 18, 2010
Anonymous
Master
Level 3:
Answers
4793
Questions
0
Helped
1544688
Points
14368
It is a rear bulb failure light,have you checked the reversing light bulbs...?
  • Dave Anderson Oct 08, 2013
    unfortunately, the reverse bulb is fine and so are the rest of the bulbs
2002 Toyota Camry fuel gauge displaying only half of what actually in tank.
Question edited to add maker.
Question moved to model category.
The fuel gauge sender in the tank is failing.
https://www.google.com/search?q=2002+toyota+camry+fuel+gauge+sender+unit
3answers
Where is the radio fuse on a 1995 camry? I do not see a fuse box under dash.
1.Answer It is a 15A fuse (#24), located in the instrument panel fuse box (behind the small fold out draw on lower the left side of dash board. Left of the steering wheel). It is the far right fuse on the middle row.
2. I had the same problem when my dome light went off. When I pulled its blown fuse, the radio went out. The radio fuse was fine, but when I replaced the dome light fuse, the radio came back on again. The dome light fuse is a 20A in the fuse box under the hood next to the battery.
3.there is on fuse in the back of the radio itself
Where are the fuse boxs for the blinkers in a 1995 camry
The turn signal fuse is located in junction box 1, on the left side of the instrument panel (dashboard). You will see 12 fuses, 3 across and 4 down. In the middle of the 2nd row is a 7.5 amp turn signal fuse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kim_3202917d7c587455
1helpful
2answers
Speedometer,fuel gauge , temperature gauge, everything stops working on my 2004 toyota camry .what could be the problem?
Pull the cluster out and have it rebuilt, many sites on the web so this repair for far less than a new one cost.
The lights inside dashboard knobs & multi-function display went out
I'm not sure what model Toyota you have, but in a Camry, the cause is most likely a blown fuse. This is a 10A fuse labelled "Gauges" located behind a cover in the dash panel
6helpful
Where is the fuel filter for 1995 toyota camry le 2.2 location
left side of engine compartment next to the air cleaner (between air filter box and firewall) bolted to inner fender
1helpful
7helpful
Fuel indicator
OK, your fuel indicator is wired to a sending unit that is located inside the fuel tank. this assembly is part of the fuel pump assembly. the fuel indicator sending unit is housed in the same assembly as the fuel pump. The fuel indicator will not function properly if there is a bad ground or, if there is a fault within the sending unit. there is a floater device attached on this assembly and, it raises with the fuel level and lowers when the fuel level is low, sending resistance signals to the indicator gauge on your dash board. these signals can be disrupted if the ground is corroded or, if the sending unit is damaged. In most cases, replacing the sending unit will fix this issue. if the fuel indicator is stuck on the full mark, check the ground. if the fuel gauge is laying on empty all the time, replace the sending unit.
2helpful
Fuel pump reset button
The two most common places are in the trunk behind the fabric on either the left or right side. The second location is near the passenger side kickplate under the dashboard. You may have to remove the panel to access the button.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
