Denon adv-500sd protect mode - Audio Players & Recorders
  • nielroach Jan 10, 2009
    I have same problem? anyway of getting out of safe mode?
Speaker wires are short curcuited
Posted on Aug 26, 2008
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
My denon adv 500sd wont read the discs can anyone help
If your unit has some time on it it probably has a dirty lense on the laser assembly. This isn't difficult to clean but you must exercise care not to damage any components of the laser assembly. Unplug the unit. Remove the top cover. If the disc drive has a cover, remove it. You should see the lense, looks like a fish eye, looking up at you. The lense is monted on a set of springs and will move around as you clean it. This is normal but do not apply anymore pressure than necessary. The alcohol will do the work loosening the dirt. Using 200 proof grain alcohol, available from any electronic parts supplier ( and commercial grade, lint free, cotton swabs, also available at MCM, moisten swab and gently touch the lense rotating the swab head. Use a dry swab after the wet one. Blow dry the assembly with canned air, also available at MCM. Reassemble unit and you should have a working player. If you still are not reading discs you could have a defective or weak laser assembly. This would have to be replaced with a new unit. I hope this has helped you. Let me know if you need any more assistance.
Thank you for using FixYa
Feb 13, 2010 | Denon DHT500SD System
Denon DHT-500SD system and want what is on TV to come through 500
You could try the optical route. You should be able to use the analog RCA audio outputs of the TV to the analog TV or VCR audio inputs of the receiver as well. Select the appropriate input on the receiver and you should have TV audio.
Jan 02, 2010 | Denon DHT500SD System
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Oct 11, 2008 | Denon DHT500SD System
Denon 1508
sterio wireing touching each other putting it in protect mode retrace all your wireing and redo this should clear up the protect mode if not return denon as manufacture malfunction to get replacement
May 30, 2008 | Denon AVR-2105 Receiver
Denon 500SD
did you get this fixed? I have the same problem. Stuck on stand by doesnt switch on from remote or the unit.
please help
Dec 28, 2007 | Denon DHT500SD System
744 people viewed this question
