Code for vcr
Changing vcr need code Sharp dodel VC A410U
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Sharp vc-a412 will not reset to zero
You have to press the clear button on your remote control to put the counter to zero.
Oct 25, 2014 | Sharp VC-A410U VCR
I still need the owner's manual for the Sharp VC-A41OU VCR. If it can be downloaded--will they say how many sheets of paper will be needed, or can it be downloaded into a folder? I am new on a computer and...
Right here :
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/VC-A410U-411U-420U-H810U-811U-820U-_E
Says it's free to download, although it may end up costing a little bit, not too sure.
Mar 05, 2011 | Sharp VC-A410U VCR
I am looking for an owner's manual for this VCR.
Right here, says they're free to DL, but there may be a small fee, not sure.
Can vc-a410u connected to my pc to record dvd ?
yes it can, as long your pc has video out (yellow rca) and of course it has audio out.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | Sharp VC-A410U VCR
I need a replacement manual for a Sharp VCR VC-410...
Hi butterfliesr, I have a user manual in pdf format if you need one. Michael.
Jan 27, 2011 | Sharp VC-A410U VCR
Adding VCR to Samsung LN40B630NIF so I can record programs.
No.
You can not recording on any VCR from a digital TV.
Nov 08, 2017 | Sharp VC-A410U VCR
I have a Sharp VC-A410 and while watching a movie play will start flashing on the screen and it looks like the movie is skipping.
try a head cleaner tape, or professional head cleaning... aslo try another tape. Videotape is easily damaged as are the heads...
Dec 29, 2009 | Sharp VC-A410U VCR
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
No remote
Check e-bay for SHARP RRMCG1236AJSA TV/VCR REMOTE
There are some for under $10 total
Jun 15, 2008 | Sharp VC-A410U VCR
Sharp vc-A410U vcr
replace the capstan motor belt.
Mar 31, 2008 | Sharp VC-A410U VCR
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
