Question about Sewing Machines
Needle won't move on Bernina 930
I am using a Bernina sewing machine and the needle will not move up and down. It will go side to side. It stopped while sewing and won't restart. I have checked all of the common troubleshooting things on the machine and none of them worked. The owner of the machine is on vacation in Ireland, so can't ask her. Help!!! I was using the zig zag stich on my machine at the edge of some fraying fabric to prepare for gathering. I had gotten about half way through the piece when the thread frayed and the needle stopped lowering itself to the fabric. Thinking it was just because of the thread, I rethreaded the machine and started to continue. The feed dog works as do the rest of the parts of the machine, but the needle will not go down. I was able to gget it to go down using the needle's hand wheel but it will not engage with the foot pedal.
SOURCE: Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Posted on Oct 22, 2007
SewTechWayne
  • 186 Answers
SOURCE: Bernina 930 won't zig zag
You probably need to take it in to the shop, the needle position knob is bound up. It's worth spending the money, this is a good machine. You can try to soak everything with penetrating oil over night and carefully try to move the knob, you may be lucky and it will free up.
Posted on Feb 08, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
mohammed387
  • 1952 Answers
SOURCE: Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Posted on Aug 03, 2009
  • 32 Answers
SOURCE: My machine stiches in zig-zag only. What did I do
Do you have a manual...if not White will email one to you at your request. Make sure the stitch width is slid or turned all the way over to as narrow as possible. Good luck.
White's toll free # 1-800-331-3164
Posted on Feb 04, 2010
Bernina 930 Record presser foot lever won't move. On the inside you can see the shaft going up and down but nothing happens to the presser foot. It is currently in the up position but won't go down.
I suspect the machine has seized due to lack of regular oiling. The old oil turns to varnish and acts like glue preventing the parts from moving freely.
CAUTION: your 930 has a basting stitch that will tend to lock up if it is accidentally oiled (or if it hasn't been used for a long time). AVOID applying oil to the middle of the take-up bar (right next to the basting stitch dial behind the case)! A frozen basting stitch is evident when the needle is at its highest point and will not descend.
Wheel on right side that controls the needle up and down is very tight...
Jun 20, 2017 | Bernina Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Sewing machine wheel won't turn, motor whirrs
So it sounds like the motor is working but nothing happens? And the hand wheel works ok by hand but nothing when the motor is engaged.
You've broken a belt. I'm not familiar with the 930, but if it has an internal motor... take it in to have it done. It's way too easy to knock these out of time. Spend the extra cash and have it cleaned lubed and adjusted too.
Sep 06, 2012 | Bernina Sewing Machines
Bernina 930 stops with needle down instead of up. How can i fix this?
There is a fairly complex mechanical interlock system on these machines that operate a microswitch on the main power supply board, so that when the needle is at top-dead-centre, the main motor is switched-off and shorted to bring it to a complete halt. Question is, does your 930 always stop with the needle down in exactly the same place or is it just not stopping with the needle up ???
Aug 20, 2012 | Sewing Machines
Bernina 930
Have you ever done a thorough internal oil of your machine? These mechanical machines rely on oil to keep moving but, over time, that oil dries and starts to stick things together. I do a deep internal oil about annually and oil the hook at least every 8 hours of sewing.
There's an oil diagram in this answer:
http://www.fixya.com/support/t26371053-am_looking_bernina_930_service_manual
How do you open bernina 930 sewing machine especially removing the side...
Feb 24, 2018 | Sewing Machines
Sep 16, 2007 | Sewing Machines
Sewing Machines Logo
148 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
