Ok the last solution still didn't work It goes back to the black reboot screen and says pxe-e61:Media test failure check cable
then,pxe-m0f:exiting pxde rom.
operating system not found
HELP!!!!!!!
Sounds like your hard drive is either dead or the cable or interface is not making a good connection. The computer cannot read the main hard drive that contains the master boot record and the computer is searching for a boot device. The pxe-e61 is the computer searching for a network drive to boot from. It then goes to the next device in it's menu. Need to check the hard drive and all cables and / or interface connections. Go through the BIOS settings and make sure the computer default settings are reset.
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM No bootable device -- insert boot disk and press any key"
install new NIC drivers from your laptop manufacture's site.
"PXE-E61 Media Test Failure, System won't boot" 1.Go to Bios Settings 2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option. 3.Save The configuration(F10) This Will Solve this problem
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
