Question about Zanussi ZEBF277W Bottom Freezer Refrigerator
The freezer is working but the the fridge
I've got a Zanussi ZI 718/8K. The freezer is working very well but the fridge is not working. What could be the pb?
  • wideawake Jul 03, 2008
    Zanussi bottom freezer. The freezer works, the pump is audible but the fridge has no cooling effect at all (3 years old). Any tips?
  • Anonymous Jul 28, 2008
    All sounds familier to me. Lots of noise and no cooling. Any thoughts welcome.....
Same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Posted on Aug 30, 2008
Hi, I have Zanussi ZERB 8441 fridge freezer.
Either the heater or thermostat is not working ohm them out to see which one it is
Aug 10, 2013 | Zanussi Refrigerators
Hi i have a zanussi zi 918\12k fridge freezer. the fridge is warm and the freezer is not working 100%. any ideas?
You more than likely have a bad relay or capacitor. Hopefully it is not the compressor. You may want to consider replacing it if is more than 10-12 years old. The other possibility is there is a leak in the freon.
Feb 13, 2013 | Zanussi ZI918 / 12K Bottom Freezer...
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Sep 01, 2011 | Zanussi Refrigerators
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Mar 18, 2009 | Zanussi ZX56 / 4 Bottom Freezer...
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Aug 30, 2008 | Zanussi ZEBF277W Bottom Freezer...
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi ZEBF277W Bottom Freezer Refrigerator Logo
951 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
