Question about HP vs15 15"LCD Flat Panel Monitor
Settings fix hi there when i turn on my panel it turns on but its all black. i checked my setings and the current settings are at 640x-60Hz, but the recommended settings should be 1024x768-Hz. do u think thats the problem??? how can i change or fix that???
  • Alex J.
    Alex J. May 11, 2010
    well, can you see the Bios information and then the screen goes black when booting Windows? does it display "Display out of range"? Are you sure the PC is not your problem? (trying it on an other monitor if possible)
    Sergeant:
  • 458 Answers
Yes you can change your video resolution to 1024x768. That will be in your display settings.
Also more suggestions.
Did you check the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Posted on May 30, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
I have a 19 inch dynex tv When I turn it on it just goes to a black screen When I get a flashlight and put it to the screen I can see the images I would like to know how to fix this problem
try changing the settings. maybe the contrast is set way to low. we did that to a friend in college and he almost threw his TV out because of it. unless you have a bad lamp inside the box? try the setings first
Feb 20, 2014 | Televison & Video
Why doesn't my magnavox led tv turn on?
if just an stand by indicator at the front panel check for bulging capacitors at the power supply board.
Sep 30, 2012 | Funai Magnavox 19" Class 720p 60hz LED TV...
Set pixels too high. Now monitor won't display.
Native resolution: 1280 x 1024 @60Hz, That is what you need to set the PC video resolution to. Running XP? Boot up in safe mode (hit F8 while booting up), set the resolution to 640x 480, then reboot into normal mode, reset the resolution to 1280 x 1024 @60Hz.
Mar 22, 2010 | Acer V193w LCD Monitor
How to font seting in epson lx300+
Hi
From the printer or printer properties in your computer, there are 2 ways actually. you can go to epson.expert.com to register to get the technical and how to's for these types of printers.
To print the current setting, turn off your printer and while off press and hold feed button and turn on the printer while holding down the feed button and release feed button as soon as it start printing current setting for your printer.
Hope this helps
Jan 09, 2010 | Epson LX-300+ II Matrix Printer
Sync out Of range
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Nov 24, 2008 | Samtron MONO TTL 13 Monitor
GPRS settings for Samsung D820
hi,
follow the below given setings.:-
Main Menu > Browser > Profile settings
• Select Profile #
• Profile name :
• Homepage URL :
• Bearer : GPRS only
• Proxy : Enable
• Select GPRS settings
• Proxy IP :
• Port :
• APN :
• Press Save
• Press Back
• Select Current profile
• Go to > press Select
2 To launch
 All APN, homepage & port & ip address will be provided by ur service provider which u need to give in above given setings..
Thanks
Gizmo11
Oct 22, 2007 | Samsung SGH-D820 Cellular Phone
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
