Question about Apple iPod MA446LL/A MP3 Player
Ipod 80gb plugged into computer to recharge battery, tried to play music then ipod froze, will not respond to any manual touch, apart from light coming on, you can see the battery charging, the time or ipod at the top, and a permenant red circle with a diaganal line running through with Do not disconnect. underneath
  • sophia65 Apr 16, 2008
    I'm having the same problem.
    Problem Solver:
  • 5 Answers
Try resetting unit - hold down men and centre button till apple icon appears
Posted on Apr 27, 2008
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
MY IPOD CLASSIC 80GB JUST FROZE. HOW TO FIX IT
Is it still on or does it stay frozen off? If it's still on and frozen, simple hold the top button and the home button at the same time and wait until it restarts and the apple logo will appear. Then if it does this again later on when using the iPod, do the same thing and plug it into the computer and do a full restore or upgrade.
Oct 19, 2009 | Apple iPod classic MP3 Player
Soon as USB is connected to computer - It freezes up and will not repond until the ipod is reset, using menu and center button. Freezes up also, when IPOD Power Adapter is connected for charging battery....
check your usb drivers are upto date
using the latest usb driver. its your pc that is at fault
not the ipod try connecting to another pc.
Ray
Oct 01, 2009 | Apple iPod touch
My ipod wont respond
Hey, simply reset your ipod
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Sep 04, 2008 | Apple iPod nano 3rd Generation
Ipod 80gb black
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Dec 12, 2007 | Apple iPod MA446LL/A MP3 Player
I-Pod wheel broken?
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
MY IPOD NANO FROZE!!!!!!!!!
Last night I was trying to play my Ipod but it didnt play. It wouldnt play any song and the timebar didnt move so that also didnt help it to work.
Dec 03, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple ipod
  • iPod classic
  • iPod nano
  • iPod mini
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Black 80gb ipod Video
Try resetting it. Hold down the Menu and middle button at the same time until the screen gets dark.
If that doesnt work, Restore it. Plug it into the computer and click "restore" when it pops up in itunes. Please note that this will erase all data on the device.
Nov 14, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
77 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
