Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
Aeg fault codes
Freezer appears to operate normally but keeps showing f5 and f8 codes on display
  • 1 more comment
  • freiston Jul 18, 2008
    same here, what does error code f8 mean freezer seems to be otherwise ok
    sue
  • freiston Oct 28, 2008
    It's a while since I had this problem but found through trial and error that the problem is as the previous post says the result of loads of Ice at the top. The solution of defrosting does work but I'd like to add that you need to allow the unit to dry out totally or any moisture will start it icing up again. I left the freezer turned off with the door open for a day or two. This solved the error code and the freezer has worked fine ever since!
  • Anonymous Dec 07, 2008
    Same again f8 is on display and freezer is beeping, any help on what I should do? Many thanks Mo
Aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Posted on Aug 05, 2009
I have this when the cooler at the top freezes completely you need to turn it off and defrost it.
Posted on Oct 27, 2008
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
I have an AEG Fridge/freezer..the fridge section stopped working last night..can it be the fuse and if it is, where is the fuse situated?
I am not familiar with your unit but It sounds like you may have more problems then you think. The freezer and refrigerator are probably on the same compressor so a fuse shouldn't be involved unless the light doesn't come on. If that is the case you have a tripped breaker or blown fuse in your house panel. Be sure the freezer is actually still working, they warm up much slower then the refrigerator. Put a thermometer inside close it and check every few hours for a few days. It will go up and down, this is normal but it should stay at least -10 or lower (guess on this unit). Check to see if the compressor is operating. Is it possible somebody bumped the thermostat while putting something in the unit?
Hope this helps as a starting point. Find a local source of dry ice in case the freezer fails, this will hold it for a while saving your food giving you time to effect a repair.
Nov 30, 2009 | AEG Freezers
Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
May 04, 2009 | AEG 7.59 cu. ft. / 215 liter Upright...
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
2,882 people viewed this question
Top AEG Freezers Experts
Charles T Nevin
Charles T Nevin
Gil Shultz
Are you an AEG Freezer Expert? Answer questions, earn points and help others
