Question about Dell Inspiron B130 Notebook
Keyboard bird removed my keys. I'v gotten everything back except for the 6 keys above F10 thru "page on". Can you tell me the sequence. Thanks, karen
    Novelist:
  • 156 Answers
Hi
This is great! Did you just "beg" it to cough up the keys? ... Well don't answer ...
Here you go
[Pn Sc][Sc Lk][Pause][Insert][Home ][Pg Up]
[ F10 ][ F11 ][ F12 ][ Del ][ End ][Pg Dn]
Pls copy this to notepad (without any formating) to display properly.
Mike
Posted on Apr 13, 2008
    Scholar:
  • 85 Answers
The order from right to left is
page up, home, insert, pause/break, num LK, print SCRN, and last button with has an icon of a page with a little arrow on it :)
hope this helps
48 gx does not turn on
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jun 12, 2010 | HP 48gx Calculator
The numbers 1-3 on the keypad wont work
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
For repairs
Jun 03, 2010 | HP 48gx Calculator
NUMBER 8 BUTTON WON'T WORK
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
May 27, 2010 | HP 48gx Calculator
Hp48gx was dropped, now difficult to turn on if at all, who can fix it
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
Apr 18, 2010 | HP 48gx Calculator
My HP48Gx has a problem with the last keyboard column(F L R X arrow / * - +). It stops working and if you shake it then it will work again. Any ideas?
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
Feb 04, 2010 | HP 48gx Calculator
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
Need how to access bios setup utility -Panasonic CF-270 Notebook.
To access your BIOS Setup please restart your laptop then during the first boot process kindly press either the following:
1. F1
2. F2
3. F8
4. F12
5. F10
6. Del
7. Esc
Cause the bios setup is design in different manufacturer of laptop so the best thing to do is read the information during the first boot of your laptop it is always display the keyboard sequence to access the bios setup.
Thanks
Jul 31, 2009 | Computers & Internet
Mx3200 clock re setting
Hold down FN and F10 which says set in blue. This allows you to reset the clock.
Nov 04, 2007 | Logitech Cordless Desktop MX3200 Laser...
Keyboard
Those keys are your function keys. They might be stuck, try turning num lock on and off. Check the manual, page 18, follow this link http://www.averatec.com/docs/3200_Series_Manual.pdf Hope this helps
Sep 14, 2007 | Averatec 3200 Notebook
Ibm thinkpad 385xd
Hi, The 385xd is a great little laptop. To change the boot sequence you need to go into the BIOS, to do that you need to hold down the shift F1 key, while the system is trying to load. You should see a blue screen with square icons. Tab over to the boot Icon.(or use the red scroll button) There should be a bird cursor, and hit the enter key, from there you can change the sequence of bootup. If you have a startup disk for win 2000, you can use that from the floppy drive after you reset the boot sequence. It will ask bring up a screen and have a list of ways to boot to the hard drive for restore. Hope this helps.
Sep 09, 2007 | Computers & Internet
Dell Inspiron B130 Notebook Logo
252 people viewed this question
Alun Cox
