Question about Frigidaire FWTBB30DS Front Load Washer
Can't get spring back onto front seal that holds the seal in place
Got the seal on, everything looks good, I try to put the spring on and it pulls the seal off. What is the trick or the tool I need to put the spring back in place.
Thanks!
  • Karoooszka Apr 13, 2008
    I've got the top, back, front and control panel off. The weights are in the way, do they need to be removed first?
    Thanks again.
  • Karoooszka Apr 17, 2008
    Thanks for everything. It turns out I had to remove the front portion of the seal too. I had the repair guy come over and that's the first thing he did. He still needed my help to get the spring on though. So either way I kind of needed a second pair of hands/eyes. I'm sorry that I didn't describe the front portion of the seal still being attached.
    Genius:
  • 1,554 Answers
Its very hard to do with the front on ,
if you have the top and bottom off you can keep trying
but removing the control panel and front is easier just a bit longer to do.
Posted on Apr 13, 2008
  • Karl Whisenand
    Karl Whisenand Apr 16, 2008
    I was trying to locate a manual for you only found this break down
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995402517.pdf
    it has 6 large carriage bolts that hold it, it is heavy and brittle.careful in moving and especially in screwing it back,
    I thought you could get around it but that manual shows it to be in the front of the spring.
    I was looking at this manual and it showed the front as one piece connected to the sides, which would be unusual. did you have to remove the front and sides together or is the manual incorrect.
  • Karl Whisenand
    Karl Whisenand Apr 17, 2008
    From what I see in the design of that washer ,it wasn't meant to be worked on ;much. kinda like the new cars.
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore door to tub spring has come off
If you are talking about the inner spring that holds the door bellow to the tub, it's going to require two hands to get the spring to go back in the groove. You will need to carefully remove the bellow from the front opening of the door, first. On the 417 models, such as yours, the bellow is usually glued in place aorund the door frame and held in place by a spring to the tub. Use a putty knife to carefully peel the rubber form the washer facing. Once completed, you can glue it back in place with some appliance adhesive. To get the spring back in the groove on the tub facing, you will need to start at the top and have someone hold it on place as you work your way around the the tub. It's a real bear to get back in at times. Let me know if this helps you. Please post back if you have questions.
Dec 22, 2008 | Kenmore Elite 45986 Front Load Washer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Door seal wire spring replacement
oh my there is no way but to take front off and you need special tool to hold the spring in place this may a job for a tech IT IS NOT FUN!!!! but there is NO WAY to put spring back on Trust me Ive tried Good luck
Dec 17, 2007 | Frigidaire GLTF1040A Front Load Washer
Door seal hotpoint 9540
undue the screws oat the back that hold the lid in place make sure washer is unplugged now open the door undue the clip that holds the front part of the door seal on this maybe a spring clip hidden under the edge of the seal or there will be a plastic clip remove and pull the clamp away now looking from the inside through were you have taken the lid off look to the back of your seal there will be a screw clamp un-screw it door seal will now pull out reverse this order to put new seal on m8
Sep 22, 2007 | Washing Machines
Frigidaire FWTBB30DS Front Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
