Dropped the DVR unit and now we are getting a screen with a lot of lines on it. If you lay it flat, the picture is fine. But if you tap the unit or move it at all, the picture messes up.
A connection has broken loose on the inside that must be refastened or soldered.
Posted on Apr 13, 2008
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
Hi everyone! I have a pioneer pdp-5071pu 50'' plasma. I'm having a screen/picture problem. 2/3 of the screen is good picture (top),then just below half screen there are two grainy green lines, then...
The Y Lower buffer is the most likely culprit. I would first try to firmly tap on the TV... about 3" below the center line on the right side front (not on the screen but right next to the screen). The Y Lower connector is there and it could be just loose. I have a Philips 50" plasma that the lower half went out and a gentle tap fixed it once. I took it apart and tightened the connectors by loosening the screws and pushing the Y Lower buffer toward the Y Main board while tightening the screws back. No problem with it since. But sometimes the buffers go bad on these units and need to be replaced. Some people replace the upper and lower at the same time while others say just replace the bad one.
Good luck and let me know what you find!
Oct 13, 2010 | Televison & Video
I dropped my camera 2 feet & now the screen just has lines on a black background. the menu & such still show up perfectly fine. So does the pictures already on the camera
See your photo on computer. you may not get lines. On primary instance it seems that due that **** your LCD screen has been stop working properly, I such case your photo will not be affected at all. Changing the LCD screen will solve your problem..
If your photo has line.. then sorry you have to get it serviced and this will cost you a lot....
Hope this has helped you. Please rate the answer.. Thanks....
Jun 24, 2010 | Casio EXILIM Card EX-S770 Digital Camera
Screen has a little scratch there is sound but on picture with little thread lines coming form the scratch
you likely need a new tv. on the insides the audio pieces are a lot tougher than the delicate pieces that create the picture for you. if it was dropped and something hit it and it cracked losing your picture, I am pretty sure the tv is toast.
May 19, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
LG HDTV large screen is blank but guide/list/pip shows up
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info.
Apr 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Swivel lcd screen
dam that suks for u i used alot of money on that camera
Jan 02, 2008 | Vivitar DVR 530 Flash Media Camcorder
3 Inch block on right side top to bottom.
your best bet is to call hitachi do not mention unit being dropped raise all kind's of hell and hope for the best.
Jun 14, 2006 | Hitachi CMP4121HDU 42 in. Plasma...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
