Question about Dishwashers
Dishwasher - GSD2220Z00BB
After starting - stopped to place another dish inside - will not restart. Has done this a couple times now. Will restart a couple hours later. What is this indicating ... problem with latch? Motor seizing??? Clueless
AllBea7@aol.com
The problem, as it turns out, was that a black wire was in the process of being completely severed, where it protrudes from door to bottom of dishwasher. Discovered when I took bottom panel off, inspected wires leading to door, and discovered the wire was partially broken - literally hanging by a thread. If door opened then closed, luck made enough connection for the dishwasher to operate. This time, one thread was not sufficient for connection, thus, it would not restart. Replaced wire and all is working fine.
Posted on Apr 16, 2008
The heater has a thermostat which will restart after cooling down for your safety.
Posted on Apr 13, 2008
How do I restart my double flashing dishwasher?
What kind of dishwasher are you talking about? What's the model number, how old is it? This information is important as not all dishwashers work and operate the same. I need more information to assist you.
Thanks
Apr 18, 2016 | Dishwashers
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Indesit Dishwasher not washing properly or draining
Could be a few problems here. The main one may be the timer. Generally the timer will tell each part to do what it needs to do and when, if it is not closing relays then you get a dishwasher full of dirty dishes. I would also check the pump to make sure it is operating properly. But I would venture a guess at the timer being the main problem.
Sep 06, 2012 | Dishwashers
I have a Frigidaire dishwasher that's just over 1 year old and I use it a couple times a week. I turned it on last night and went in another room. appox 30 minutes later my daughter came in and noticed the...
Someone squirted dish soap in there instead of regular dishwasher detergent...
You will need to manually rinse out the soap and use the right soap...
heatman101
Sep 18, 2010 | Dishwashers
Dishes recently started feeling gritty after cycle is complete. I cleaned the dishwasher, ran a full cycle w/o dishes, and added JetDry, which has helped some, but problem persists. The unit occasionally...
It is possible your dishwasher is dirty. I have found this wonderful product called "Dishwasher Magic" It cleans rust, midew and scaling from deep inside your washer leaving it like new. Try it it's a wonderful product
Nov 18, 2009 | Refrigerators
I have a white film left on the dishes i've had this dishwasher for about 4 years and this just started
Place a cup of vinegar in top rack corner (upright) and run an empty cycle to clean any build up.
Stop using any rinse-aid (jet-dry etc.), if the detergent you're using already has it included. Too much rinse-aid can create a white film on your dishes. A good way to check for rinse-aid build up is to run your fingers on the inside of the cabinet and check for a white powdery residue on your fingers. You can also run the dishwasher for a couple of minutes and check for excess suds in the water when you open it. Excess suds would indicate a rinse-aid build up.
Run the hot water at the tap before starting the cycle and make sure it's at the recommended temperature (120-140°F).
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Motor and pump replaced still not getting dishes clean
Food particles left on dishes. Whirlpool quiet partner 1
You do not have to take it apart to clean it. You can run it a couple of times with dishwasher tablet and it will self clean. In general I recommend rinsing the food off of the dishes and silverware before placing items into the dishwasher. Also, run the hot water in the sink until it gets hot and then turn on the dishwasher. good luck with it.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
