Question about Vacuums
I cannot get the belt back onto my G4 Kirby vacuum
    Genius:
  • 1,554 Answers
Remove the brush assembly and it will go on easy.
clips on side
Posted on Apr 13, 2008
Change belt on Kirby heritage vacuum
It is the same as installing a Kirby Generation belt.
Here is a walk through:
Install Kirby belt and nozzle
800-775-6586
GpodVac com
Sep 15, 2014 | Kirby Vacuum Fan Heritage G3 G4 G5 Ult G...
How do you replace the belt on a G4 Kirby Vacuum?
Remove the head from the machine, and unlatch and remove the bottom plate. The brushroll can now be pulled or pryed out. Slide the new belt onto the brushroll and center it. When re-installing the brush, note that one end cap is wider than the other. The brush caps are also marked with 1, 2, or 3 notches to adjust for wear. In normal use, setting 1 should face the carpet. Be SURE both ends are on the same setting. Replace the metal rug plate and turn the belt lifter counterclockwise to stretch the belt into a loop. Place the head back on the machine, latch it firmly in place, and turn the belt lifter clckwise to drop the belt onto the motor shaft.
Jan 28, 2011 | Kirby G4 Bagged Upright Vacuum
The green light is not coming on and kirby is not sucking
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
May 14, 2010 | Kirby G4 Bagged Upright Vacuum
How do I replace the drive belt on a kirby G4? Actually the belt is already replaced I just need to know how to reattach that front part back onto the main vacuum. HELP
Greetings from GoVacuum,
Here's a video we shot showing you in detail how to install a belt properly, and how to reattach the head properly. I hope this helps you;
Jan 30, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 causes black streaking when shampooing carpet
Replace the belt it is probably worn. You can get a replacement here:
Kirby G4 Belt
Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Brush
Put the belt over the brush roll, set it in the middle, put the brush roll into the head and put on the bottom plate. Turn the big knob on the front of the nozzle to catch the belt, turn it until it locks into place. Then put the nozzole onto the front of the vac, then turn the knob all of the way the other direction, it will put it on the motor pulley.
Jun 01, 2008 | Kirby G4 Bagged Upright Vacuum
Manual and tools kirby g4
The first link is instructions for changing a belt. The second is for the shampooer instructions. If you click on the links below, it will take you to my online guides and if you look there, your other question will be answered. Thanks!!
Marci
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Oct 29, 2007 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
