Question about Cameras
CAMRA MY LENSE IS STUCK IN AND WHEN I TRY TO ZOOM IN AND OUT IT SEYS LENSE ERROR 2111 AND TEHN SHUTS OFF... WHAT SHOULD I DO?
    Genius:
  • 1,554 Answers
You have jammed the 3 lens studs outside of the track , you cannot fix it without dissembling the entire camera to the lens,
its best to leave it alone and sell it on ebay for the lcd is worth 35 to 60
Posted on Apr 13, 2008
Canon powershot zoom lense is stuck how can i get it to
There are a few things you can try. Here is an excellent blog about lens errors and stuck lenses, and it covers what can be tried to free it up:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
They say about 50% of lens problems can be fixed trying their suggestions. Hope you're one of the lucky ones! Also, if nothing works, get an estimate before having it repaired. Often, it's just better to get another camera.
Jul 09, 2010 | Canon PowerShot A540 Digital Camera
Sony cyber shot camera lense stuck halfway.
    According to the symptom your camra needs replacement Lens block, It is due to malfunctioning of zoom motor. The part No along with description is given below:
1-788-363-11     OPTICAL UNIT
  Replace the unit with new one and it works fine again.
  Thanks for using fixya.
Oct 31, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lence error 2111 on sanyo s870
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jun 17, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Lens error 2111
Try to find the reset function in the menu. Or bring it back to the "default" or factory settings. Also check if the date is correct.
Nov 11, 2008 | Microsoft Troubleshooting Your Web Page...
Error 2111 on camera VPC-S750 when i try to zoom in it says lens error 2111 and shuts off. the lens does not close when i turn my camera off.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sep 07, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Zoom and camera shuts off
Verify you have the right kind of battery and fully charge it.
The lense issue you describe commonly happens when the device cannot access enough power to function correctly, so it retracts and powers off to avoid getting your lense stuck in the 'out' position if the battery goes dry.
Apr 27, 2008 | Kodak EasyShare One Digital Camera
Digital camara zoom
samsung digitmax d73 zoom lens will not retract, just pull lens outward gently it will click, then turn on camra ,you should be able to zoom now turn off camra lens should return & close
hope this helps
Oct 17, 2007 | Samsung Digimax S600 Digital Camera
Zoom lense stuck
The only solution is to replace the lens module.that module is very costly. hope it help
Aug 09, 2007 | Fuji FinePix F460 Digital Camera
Cameras Logo
257 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
