Question about Microwave Ovens
Retainer gone While mounting my microwave hood combo I pushed on the top mount set screw and accidentally pushed the retaining nut out and into the microwave case. It is unretrievable unless I take the whole thing apart. Is there an alternative to replacing the lost retainer?
    Genius:
  • 1,689 Answers
I would take the the microwave to a service center to take the case apart, and you can get a new part if necessary.
I would not recomend you take the case apart yourself unless you are very familiar with what to expect, and the safety precautions that are necessary.
For safety sake, you don't want something inside this appliance that can eventualy possibly cause a problem.
Jerry G.
Posted on Apr 14, 2008
Kenmore 721.80012401
Chances are the thermal fuse is gone that protects the magnetron. Unplug microwave, remove top, [several screws] look over to the keypad and slightly to the left, you should see round fuse mounted on the inner chassis at the top, change with the same size and rating, if all goes well the microwave oven should function.
Jun 24, 2012 | GE JES735WJ Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
I want to remove/replace a 2000 GE JVM1640WB microwave and don't know how to access the mounting/securing screws to allow me to remove the old unit. Are they behind the top grill, which looks like it's...
I have found and provided a link installation instructions for your existing model. The front is held in place by two screws through the cabinet above into the top of the micro and the back is supported by a wall bracket. A new microhood will fit into the space, but will install a little differently. link to instructions:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675895.PDF
Dec 25, 2009 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Installation of undercabinet microwave
If the OTR is the same model, the mounts should be the same. As long as you use the same bolts/screws from the old one, or the same length new bolts/screws, it should be a fairly simple exchange.
Mar 24, 2017 | GE JVM1440 Microwave Oven
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
Installing a microwave hood combo
the plate goes on the backsplash and two holes on top go inside cabinet that you have to drill
Jan 17, 2009 | KitchenAid KHMS147 Microwave Oven
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Replace Blub GE Microwave oven Model 1540
On my Spacemaker, access for bulb replacement is on the top of the chassis, which is under the top/side cover. From a diagram I looked at, it appears that yours is similar. If so, you have to:
1. UNPLUG the microwave and then remove the three retaining screws that you'll find on shelf or cabinet above the microwave. Get help; the front of the microwave will be heavy when the screws come loose from the top.
2. Rotate the front of the microwave down a little and lift the rear up about a half-inch. At this point, it is free from the rear mounting plate. Set the microwave on a suitable work surface.
3. Remove the top/side cover piece. To do this, remove all the small screws on the top, the back, and the bottom edges on each side. Then slide cover back about an inch and lift it off.
4. In the middle section of the top of the chassis, you'll then see a cover above the location of the bulb. Lift it up to get access to the bulb.
It's a lame design for an over-the-range unit, but that's the way it is.
Here's a link to a diagram of what it looks like after you get the cover off: http://www.partselect.com/MultiModels.aspx?ModelNum=jvm1640sj&searchTerm=img_00115013i05&RefineSearch=0&imgMfg=GE
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
