Question about Panasonic Office Equipment & Supplies
Pencil sharpener fuse 400ma, 125V, can't locate replacement part anywhere. will 500 ma, 250v work as a substitute?
Where do i buy a 400 mA 125 v fuse from?
Posted on Dec 17, 2009
How do you test a fuse
How do you test a fuse?
• for RCA FL231
(400ma, 125V) +40V Supply Power Supply/Deflection PCB
OEM RCA FUSE RCA259213 FL231 400MA 125V 3960400000 ...
• for
FL221 (1.25, 125V) -13V Supply Power Supply/Deflection PCB
FL251 (1.25A, 125V) +13V Supply Power Supply/Deflection PCB
FP400 (6A, 125V) AC Input Mains Input Doubler PCB
FP602 (1A, 250V) DVD Power Supply Mains Input Doubler PCB
here are some links to guide you:
http://www.electronicrepairguide.com/how-to-test-a-fuse.html
http://www.dinosaurelectronics.com/Test_Fuse.htm
hope these helps,
thanks for choosing fixya for assistance!
Aug 25, 2012 | RCA HD52W59 HDTV Projection Television
My picture tube looked bowed and in 3D. What is the problem?
change the convergence fuse located next to the flyback its red and shaped like a rectangle ref fl321 number . part number is 259213 400ma 125v you can order at ebay or from newark com for 51 cent there part number is 67K2174. its the same fuse.
Sep 11, 2010 | RCA HD52W59 HDTV Projection Television
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Replace a fuse R52WM24
you can temporarially. Its recomended not to exceed fuse ratings especially the amperage do to pretective reasons. You can get the proper FL231 fuse at the following link. They have a 10.00 minimum order for free shipping so you may have to order enough fuses to add up to 10.00 or pay for shipping if under 10.00 Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA fl231 fuse
www.vancebaldwin.com has them they are RCA part number 259213 they are a 400ma 125v fuse.
Jul 17, 2008 | Televison & Video
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
438 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
