Question about Oreck XL Professional Air Purifier
Oreck XL air purifier (Tower Model)
Oreck sent me 4 new wires. I had 2 broken. I replaced them which was a very easy task. After a day of running the red light came on and will not go out. I cleaned the collector cell, but light stays on. This purifier is about a year old, but since we don't live near a repair center I have to rely on myself to keep it going. The collector cell looks good visually.
I am very impressed with their vacuum cleaners, but feel I got hosed on this air purifer.
  • 2 more comments
  • thermoak Apr 15, 2008
    The unit is dry, and like I said, it did run for a day before the red light came on. There is no "red button" on the tower model. It has a red LED that is labeled "check collector cell".
    Any other ideas ?
    thanks
    Since I'm an electrician by trade those are two of the things I checked first. No sign of either.
    Are there any voltage readings I should be getting or not getting on the board?
    thank you
  • thermoak Apr 16, 2008
    There is no red button to push.
  • Anonymous Mar 16, 2014
    oreck xl check collector cell after cleaning red light
  • 3,037 Answers
Is this purifier wet at all, or been in any heavy areas of moisture. This purifier is very undependable with moisture. It may just have to dry out. Let me know if this solves your problem or we can explore further options.
Please keep me updated, thanks
Posted on Apr 13, 2008
  • Benjamin Patri
    Benjamin Patri Apr 13, 2008
    You can also try to hold the red button in and it will go off after a minute or less. Then it should reset to green.
  • 19,396 Answers
Check for an eventual short or lose contact, if it is all right then you brobably need to replace the contol board
Replacement motor
Did you check out ebay? Google it.
Mar 02, 2016 | Oreck XL Professional Air Purifier
Need a wiring diagram for Oreck XL air purifier Air8SD
I would look at the board using a high powered magnifying glass to see if there was any signs of broken stubs of wires sticking out of any solder joints. Also look for solder joints that have no other possible routes, (dead ends) that do not have any other connections running from them. Like a resistor that has a copper path on one end and nothing running from the other end. Or it could be a ground wire if no other spot is found.
Aug 04, 2014 | Oreck Air Purifiers
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
Aug 01, 2014 | Oreck XL Professional Air Purifier
What happens having one broken wire?
Not trying to be funny, but it depends on the wire, if your air purifier is still running or not, whether you have lost hi/low settings etc. Or is your plug wire and you lost the internal ground wire. Attached link you are able to download user manual. Need to be more detailed, color of wire, location of break. Hope this helps, or provide make model, and other details. PEACE
http://www.oreck.com/userguides/global-user-guide.html
Redirect Notice
Jun 07, 2014 | Oreck XL® Tower Air Purifier
Where can I get replacement wires for an oreck truman cell? Seems silly to spend 200 dollars when the only thing wrong is four 29 cent wires does it not?
Here is a link to where you may can find what you need. You will need to have the correct model number (not just XL Tower Air Purifier) , to find your mode.
http://www.ereplacementparts.com/oreck-air-purifier-parts-c-130239_130321.html
Hope this helps you find the wiring you need. Thanks for choosing FixYa.
Sep 19, 2011 | Oreck XL® Tower Air Purifier
Hi, i own a oreck XL professional air purifier
You can download the manual at
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Jun 13, 2010 | Oreck XL Professional Air Purifier
How can you tell if the oreck tower works.mine used to collect surface dirt on the small horizontal pains at the bottom of cell now it doesnt
Take it into an Oreck dealer, first they'll try to sell you a new one, don't buy it. Then they will happily help you out with whatever parts you may need.
Feb 20, 2010 | Oreck XL Professional Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Red light wont change back to green after cleaning
I did the same thing and now I need to replace the cell collector. You need to replace it to if the wire is broken. Please let me know the outcome of your problem.
Where to find the part is hard to get.
animallover2
Jun 05, 2008 | Oreck XL Professional Air Purifier
Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Dec 03, 2007 | Oreck (AIRCOM1WOI) Air Purifier
Oreck XL Professional Air Purifier Logo
776 people viewed this question
Top Oreck Air Purifiers Experts
brian kossman
Level 1 Expert
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
