Question about Microsoft Xbox 360 Console
Xbox 360 AC Adapter Problem
We have two Microsoft Xbox 360 AC Adapters. Both of them, when plugged in, only show the orange (standby) LED status. In using either one, the Xbox will not power up. What's up?
  • AudiS4 Apr 13, 2008
    Yes
    I still cannot get the console to turn on. The cd tray will not open as well.
  • Microsoft Master
  • 1,183 Answers
There could be two points of failure
the Power supply second the front power button.
Switch of the Xbox and disconnect the power cord ,press and hold the power button for 10 seconds.Reconnect the power cord , press the power button and try ejecting the cd tray , if they tray comes out , this means the powersupply is OK , if not then there could be an issue with the power supply.
let me know if additional help is required, coz we might need to open the xbox to find out the the failing part
Posted on Apr 13, 2008
  • Microsoft Master
  • 19,396 Answers
They can be both faulty, or there is a short in the xbox power socket
  • Microsoft Master
  • 13,433 Answers
Its most likely not the ac adapter and there is a hardware side fault in your xbox, Il have to check this with microsoft.
Il get back to you.
  • Ekse Apr 14, 2008
    test the ac adapters in another xbox? does your friend have one?
    if they work in your friends xbox then, it seems to be a hardware problem with the xbox, contact your dealer or microsoft for repairs.
    if you need more assistance let me know. I'm here to help.
    Scholar:
  • 85 Answers
Hi there
try the following steps as recommended by microsoft themselves:
http://support.microsoft.com/kb/906102
hope this solves the problem
The light is flashing orange on adapter and no power to system when turned on
It is possible that there is some foreign particles inside one of the connectors. Since the power supply does come apart and also disconnects from the unit, you can try to clean it to see if it will sort out your problem. Here's what to try:
1. Disconnect the AC adapter from the wall and the console. Let it rest for a few hours so that you do not electrocute yourself.
2. Disconnect the wall power cord from the AC adapter brick. Check the connections on both ends to see if it needs to be cleaned.
3. Clean any ends of the adapter with alcohol solution (isopropyl, or "rubbing" alcohol). Make sure the connection to the console is clean as well. Allow to dry.
4. Reconnect all necessary parts and try your console again.
If that does not work, there could be another problem with power flow to the AC adapter or a problem with the adapter itself.
Feb 28, 2011 | Microsoft Xbox 360 Console
360 won't power up power supply good is there a fuse
They dont have a fuse in side them , it could be dry solder joints on the main pcb where the power plug goes into the xbox, make sure you try your power supply on another xbox as well as your xbox on another power supply. Also check the led on the power supply is green when its running, if the light is orange or red(whislt running, the light will be orange when in standby) .If your led on the power supply is red , you have a faulty power supply. Good Luck.
Sep 24, 2009 | Microsoft Xbox 360 Console
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
X360 AC Adapter stays orange
try to unplug and plug in a few time otherwis cant help ya never had that problem
Apr 14, 2009 | Microsoft Xbox 360 Arcade
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
Feb 06, 2009 | Microsoft Xbox 360 Console
X-box 360 has blinking orange light on ac adapter and will not turn on.
well then if the orange light does not turn on then you have not connected something the right way or thers something not plug in the right way ok
Nov 01, 2008 | Microsoft Xbox 360 Console
AC Adapter has a blinking orange light...
Try moving everything to a different room on a different electrical circuit (as in electric panel outside your house). You might have too much load on that circuit for the plugs in that room. You could try unplugging everything except tv and xbox too.
Oct 29, 2008 | Microsoft Xbox 360 Console
Battery Pack or Ac Adapter
check the light on the box. if it has no light no power is getting to the box. if its red then it could be a xbox problem. yellow is standby and green the xbox is turned on.
Sep 15, 2008 | Microsoft Xbox 360 Console
Xbox 360 red lights power supply light stays yellow
you have to disconnect and reconnect the power cables to the 360. Orange/yellow light means that your power supply is on a standby mode and the 360 is not getting enough power/electricity inside
Mar 04, 2008 | Microsoft Xbox 360 Console
Wireless adapter
What exactly are you refering to Here ( adapter ) The Power Brick, A wireless or wired Controller ?
There are 2 USB Ports on an XBOX 360 same place Front R/H/S Slot Side By Side.
Mike @ Compurepair.
If it,s Orange ( whatever it is youre refering To ) then it,s in standby Mode. Red ( error/Fault ) Green working OK.
Hope this helps.
Feb 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
284 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
