Question about Husqvarna Viking 1
Reverse stitch The reverse stitch is not working on my #1+ machine. Any suggestions on what the problem might be.
  • Husqvarna Master
  • 1,388 Answers
Gummed up with lint and old oil is the most likely.
If you place the unplugged machine on it's back & remove the base and press the reverse lever to see where the connecting rod is attached, you will see something like a collar around the shaft.......you may be able to move it bu hand and it may feel stiff.......use penetrating lubricant (like WD-40) and target spray to the shaft and aim to get between the shaft and collar by manually moving the collar back and forth......it may take several applications to work, and sometimes longer...just wiggle it for 30 sec a few times a day...most recent old singer was 17 days and may applications over that time !!
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 14, 2008
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
How to fix sewing reverse
try to pull the fabric as you hold the reverse lever.....pull away from front towards yourself. the dogs pull the fabric in the opposite direction. make sure your stitch length is narrow or "1" ...reverse only works with a straight stitch foot not a zigzag. Sometimes a machine needs a little help getting the reverse mechanism going......
Feb 12, 2015 | Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
I have used consew bls-600 industrial sewing I purchased recently. The stitch length 0-4 dial was not working and was very tight. I tried to open it. Now the reverse handle is also not working and t
Shorten your stitch in reverse the machine can't do a stitch that long in reverse. Also google your make and model machine and the word Manual so you can properly learn to use the machine safely.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 04, 2014 | Consew Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Stitch length not working and sticking in reverse
sounds like it needs servicing and cleaned. Suggest only using authorized husqvarna viking dealer for service. You can find your local dealer at the Husqvarna Viking website http://www.husqvarnaviking.com and selecting "dealers" link.
Feb 11, 2010 | Husqvarna Viking 1
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
Machine won't go into reverse
What model machine are we talking about here? If it is a Designer 1, Reverse doesn't show up on the screen. You need to hit the Reverse button twice in succession, the button stays lit up, and the machine should sew in reverse until you hit Reverse again or change stitch.
When a reverse arrow shows on the screen, it is usually when a programmable stitch is selected and you need to hit Reverse to complete the programmed task.
Get back with more detail on your machine and the problem, and maybe I can offer some more specific help.
Pamsquilt
Oct 17, 2008 | Husqvarna Viking 1
Reverse Switch Control on my Kenmore Sewing Machine
My back swith button is not working on my Kenmore sewng Mchine. Can you tell me what the problem is?
Aug 25, 2008 | Kenmore 15516 Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
380 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
