I have a oleiva tv 532B12 and I do not be able to get a univeersal remote to work with it. so I am stuck using 3 remotes, is there a cure for this lewis597@yahoo.com
    Genius:
  • 1,554 Answers
No cure , the manufactures remote codes are not standard,
only a learning remote can solve your issue, they cost 50 to 100 but replace all your remotes.
Posted on Apr 13, 2008
I need a manual for a LM-1075 univeersal remote.
The directions tell you to find the proper code to set up the remote. You have several Codes to choose from and one will eventually work. Get a Fresh start, review the setup procedures well, and do your step by step application. Don't get upset when one code after another fail, as eventually you will unlock the mystry.
Dec 18, 2013 | Televison & Video
The remote or buttons on tv don't respond
hey try to change your remote . how many years has that remote ? if has more than 2 my advice change it
Dec 15, 2013 | Toshiba 65HT2U 65" Class Full HD LCD HDTV
Need remote codes for olevia tv model 532b12
037,033,038,031. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 13, 2013 | Syntax Olevia 532H 32 in. LCD HDTV
Vizio remote won't control tv
I just had the same problem. I call Vizio and this is what they had me do that did fix the problem.
1. Unplug the TV
2. Hold down the power button on the TV for 30 seconds (yes, with it unplugged and do not plug it back in yet.)
3. Take the batteries out of the remote.
4. Press each button remote twice to ensure that they bounce back and are not stuck.
5. Place new batteries into the remote.
6. Plug the TV back in. Not into a power strip if possible. ( I did not have an available outlet so I used a power strip.)
7. Try turning the TV on using the remote. (My TV turned on. All of the functions worked - problem fixed.)
Hope that this helps.
Nov 17, 2013 | Vizio New Original M3D550KD Remote Control
How do I program the tv to use without cable?
1.Power on the television and press the "Menu" button on the Olevia TV's remote control.
2 Choose the "Programming" option to view all of the Olevia setup options.
3 Choose the "Channel Program" option, then select either "Antenna" or "Cable" (select "Cable" when using a satellite receiver).
4 Select "Start" and the Oleiva TV scans over all the stations it receives. Once complete, is stores the information into its memory bank, so when you attempt to change the television station you only see programs that come in clear onto the TV.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Olevia LT42HVi 42 in. LCD Television
Stuck on 3 channels, no remote.
U can't get to channels 3 or 4 without a remote.Ur getting stuck on these particular channels 26,35 and 19 mean the last owner put these channels on the tv memory.Try website like Remotes.com to buy an exact remote or very close to the original,if u want make use of this tv.
Jun 15, 2010 | Sylvania 6420FB 20" TV
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
