I just installed a new oven and after we hooked it up we turned it on..it was running fine for a few minutes when it shut of and now the preheating light keeps flashing..do you know what the problem could be
-   Power out.... Range no longer working. I have blinking lights but no main oven.-   mindskew
Nov 27, 2008
-   We have the same problem. Thermador Dual Oven not working after a power outage. Flashing Oven and Heating lights. Small oven and gas range work. Any suggestions would be greatly appreciate.-   sriazi
Nov 23, 2008
-   Only my main oven doesn't work, with flashing lights. Range, griddle and small oven are fine. I would love that code sheet. I have the dual fuel 6 burner with griddle and two ovens.-   rkfatheree
May 30, 2008
-   Hi,
Yes we had our 36 Pro range installed & the oven worked fine. Now a few days later, we have a blinking oven light & blinking heat light the oven does not turn on. Very frustrating, any solutions?
T.H-   Guest
There is a code sheet that tells you what the problems depending on the sequence of blinking lights, but only the authorized dealers have this information. I do have a copy if you want to email me and I will forward it to you. detlvng@bellsouth.net
Was this helpful?
Yes
No
Popular Solutions for Thermador PDR366ZS Dual Fuel
I selected the self clean mode, forgetting to set the time. i turned it off. Now I have a beeping...
(More)
I selected the self clean mode, forgetting to set the time. i turned it off. Now I have a beeping sound and a display F93 when trying any function
Our stove has worked well and suddenly, the oven comes on and it will not turn off when we push the...
(More)
Our stove has worked well and suddenly, the oven comes on and it will not turn off when we push the cancel button. We have had to turn off the circuit breaker. We cannot see how to slide the range out from the counter. Anyone have any ideas. At one point there was an F-1 code but we were unable to identify it.
oven control beeps and displays f1, what does this mean? can find the meaning of all the codes on...
(More)
oven control beeps and displays f1, what does this mean? can find the meaning of all the codes on the web.
our thermador range has an electric oven it is model# pd36 dual fuel model. recently we noticed that...
(More)
our thermador range has an electric oven it is model# pd36 dual fuel model. recently we noticed that it has been taking alot longer to preheat . both the lower element and the broiler element are working but they do not get as hot as they used to . they heat up but do not glow red like they used to . it is as if they are working but at only half power.
