Question about Panasonic PT-47WX49 47" Rear Projection Television
PT-47WXD63G The very bottom of my screen is mising. How can I make a slight adjustment?
    Genius:
  • 1,554 Answers
If its time warner you likely have zoom on . press the #
Posted on Apr 13, 2008
How to replace bulb on panasonic pt-47wxd63g ?
This model has three picture tubes and no bulbs or lamps.
you have provided a model number and if you tell me what set is doing or not doing I may be able to help.
Dec 23, 2012 | Televison & Video
I fix the red doubling by adjusting the red screen screw now the people are greenish. can someone help me. pt-56wx53g
turning the red Screen down even slightly will make the other two CRTs dominate over red. You may be able to turn the Green and the Blue down slightly to balance them back to what red is at. Turning the screens down too low will cause them to shut off if they get lower than the cut off point.
Sep 15, 2011 | Panasonic PT-56WX53 53" Rear Projection...
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red horizontal convergence PT-47WX49E
converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
Oct 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Pt 47wxd63g
trace your video path from input to output
Oct 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No sound, no picture, power light blinks
i have a model #pt-53wx42f when you first turn the t.v. on it gets shakey and distorted then it shuts down and the power button light starts flashing
Sep 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
2003 PT-47WXD63G...NO Sound/NO Picture
by pss your sat. to see if audio returns if so ck. settings on sat, box.
Mar 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Projection off the screen?
Try pressing the "Aspect/Prog -" button on the remote - it should be just underneath the number 9 key - try pressing once, see if it fits better, try pressing again to see if it improves until you get a better match
Feb 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Aug 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Pt-47wxs1ce green wave at bottom of screen cannot adjust green convergence
you have bad convergence IC's and possable 1 bad resistor
let me know and i will help you find them in the set if your are a good solderer - or call a tech
thanks
scott
Aug 30, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
