My washing machine has stop with washing inside
    President:
  • 1,294 Answers
Press 'end of cycle' button & wait for 3 minutes before trying the door. Do not force door.
Posted on Apr 13, 2008
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
My washer machine start working for a little bit and after that just stop stop
maybe the motor form your washing machine stuck or inside gear has lossen .
Mar 08, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
MY WASHER STOPS WORKING WHEN IT IS SUPPOSE TO DRAIN TIMER EVEN STOPS WHAT COULD BE WRONG?
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 09, 2011 | LG WFT1071TP Top Load Washer
Spin does has stopped working. all the functions work normally but the washer has stopped spinning.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Here is a link to the part you will need.
Jan 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
When the washing machine is off, water continues to slowly drip inside the washing machine. If we turn off the water where the hoses are connected to the wall, the dripping stops. Any idea what might be...
Could be a build up of limescale inside the water inlet valves stopping them from sealing properly when they close. Unless you feel confident enough to take it apart you should get an engineer in to look at it.
Feb 02, 2010 | Kenmore Washing Machines
Washing machine won't stop draining water
To take your clothes out,just unplug machine's power cable and you should be able to open the door. Why do you think that your "machine thinks that there is still water inside it when there isn't" ?
Sep 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
