Question about Sanyo PLC-XT11 Multimedia Projector
Projector Won't Turn On
The ready and lamp lights are on, but when I press the on/off switch, the lamp light dims as if it is about to turn on but it doesn't. The ready ligh will turn off and the fans will come on then the projector shuts itself off.
  • 3 more comments
  • James12B3 Apr 13, 2008
    I have cleaned the filters but that did not work.
    The projector is not hot at all. Actually it is blowing cool air. I tried changing the bulb also but it still does the same thing.
    Thanks. I tried replacing the bulb and cleaning the filters but I'm still having the same problem.
  • James12B3 Apr 14, 2008
    I have taken it apart, cleaned it with compressed air and changed the lamp. It still will not stay on. Sometimes the warning temp light comes on.
    Master:
  • 788 Answers
I beleive that the thermal protection circuit is at fault. Maybe the thermistor is shorted out and the projector thinks it is perpetually over-heating.
Posted on Apr 14, 2008
  • 871 Answers
Gosh. have you tried turning the contrast on? if you have just serviced the projector, chances are, its not the projector anymore but the connection to the pc or the video setting of the pc itself.
please do check.
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 14, 2008
    See instructions on pages 19 and 42
  • Sanyo Master
  • 13,433 Answers
Only the ready and lamp lights are on so
it means that there is no overheating. so thats not the problem.
There might be a circuitboard hardware problem.
The lamp light isnt on so its not a lamp problem,
It can be the lamp even thought there is no lamp replace light on.
OR then its hardware.
Id suggest takeing it to a professional to be analysed since we dont know if its a lamp or hardware problem.
Posted on Apr 13, 2008
    Brigadier General:
  • 3,614 Answers
Have you the projector ballast & lamp, it possibly need to be replaced and have to installed a new one. That why the projector shut's off coz it never get enough power and light source on the ballast area..
Buyin a set of a ballast kit would be avaible the same as the model of your projector.
  • 1,183 Answers
The lamp needs a replacement , thats the only thing wrong on it
  • 3,037 Answers
It might be a cooling problem. Since the fans start up maybe much higher than normal, that would indicate that it may be overheating since projectors normally do this along with many other electrical devices. I would check to see how clean the projector is especially the vents and take some compressed air to it after cleaning it with a cloth and getting as much dust as possible off of it. Let me know if you still have this problem after doing this.
While cleaning it, please have it off so that it may cool down faster and possibly reset itself back to a normal operating state.
Good luck with this.
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri Apr 13, 2008
    Is the projector excessivelly hot?
  • Benjamin Patri
    Is the projector excessivelly hot? You may have to
  • Benjamin Patri
    Is the projector excessivelly hot? You may have to replace
  • Benjamin Patri
    Is the projector excessivelly hot? You may have to replace a
  • Benjamin Patri
    Is the projector excessivelly hot? You may have to replace the
  • Benjamin Patri
    sorry, my computer was going nuts
    bulb might be bad too or may need to get cleaned itself
  • Benjamin Patri
    Benjamin Patri Apr 14, 2008
    check for crossed wires (and broken, possibly just the insulation) and for any lose pieces on the board please and then let me know what you find
    Genius:
  • 3,422 Answers
HI,
Sounds like it may be overheating, have you cleaned the air filter. If the unit gets too hot, the projector will shut its self down.
Goodluck,
Please don't forget to rate the solution
  • Priya darshan Apr 13, 2008
    Hi again,
    the problem appears to be with the bulb. Once the bulb gets 'tired' the
    filament becomes 'stranded' and the running temperature increases
    massively. The safety mechanism of the projector cuts in before serious
    damage occurs.
    Interestingly, using big external fans didn't
    solve the problem, but turning the projector upside down does
    (presumerly the heat sensor is at the top of the projector).
    Solution: Buy a new bulb, or for what bulbs cost, but a new projector!!
    Please don't forget to rate the solution.
How do I turn off the machine safely?
Do people still use those?
OK. Dim the lamp, leave the fan on for about 10 minutes.
Turn off unit and LEAVE UNTIL COOL.
Feb 13, 2015 | Apollo Ai-1000 Overhead Projector...
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
Sanyo PLC-XU33 image displayed for 10 seconds then turns off
Owner decided to upgrade to a newer projector. Lamp was too expensive.
May 07, 2009 | Sanyo PLC XU33 Multimedia Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Its not the lc-sb20 but the lc-nb3e
Hi there
This sounds like a common Ballast ( lamp's power supply ) problem.
Only way to rectify this is by replacing the faulty Ballast.
Sep 08, 2007 | Eiki LC-SB20 Projector Multimedia...
Projector does not turn ON
try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Dec 24, 2006 | Canon LV 7345 Multimedia Projector
Sanyo PLC-XT11 Multimedia Projector Logo
295 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
