TV will not come on and making a loud squelling sound when pluged in to the wall outlet.
  • 8,617 Answers
Your flyback is most likely the problem. What is the model number of your set?
Posted on Apr 13, 2008
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
What to do when panasonic tv sparks at the outlet it is pluged into
If TV do now work at all, and the spark occurs when you plug it into the wall power outlet, surely there should be some short circuit inside any circuit board, and you should contact any service technician to rectify the problem. google.com/+GopakumarGopalan
Nov 25, 2013 | Panasonic Televison & Video
My furnace makes a loud noise on start up
What kindof sound? Is it a squelling kind of sound?
Jan 03, 2013 | Heating & Cooling
My hp printer is making loud noise when i want to print
I had trouble with mine too, I unpluged it and then pluged it back in and that seemed to fix the problem,
May 19, 2012 | HP LaserJet Pro M1536DNF Multifunction...
1992 Pickup: loud squelling sound under hood when started...
Sounds like a loose belt.
There are a few things that can cause a belt to slip like that.
The belt could be not tightened all the way. If it uses a sepentine belt with a tensioner, the tensioner could be bad. If it is not a serpentine belt, then you will have multiple belts and the one that is making the noise can be loose. Use something to pry it tight and tighten down the bolts holding the component th belt goes to.
It can also be a bad pulley. Pulleys have bearings inside of them, at times the bearings will go out and make the pulley hard to turn. You can usually find this easily by taking the belt off and turning the pulley with your hand. If it is hard to turn or makes a grinding noise when turned...it is bad and needs to be replaced.
Old belts can also cause this along with a belt that is wet. There is a spray on Belt Dressing that helps get rid of noisy belts, but I consider that a bandaid to a bigger problem.
May 03, 2010 | Toyota Cars & Trucks
I Have No Audio I Have Regular Standard Cable and Its pluged To Tv And We Bought A Audio Cable Plug And Also Pluged it To The Cable box and Tv And still do not have audio
Hi:
Check you menu options and make sure under audio menu the speakers are not set to off posistion. Also reset the cable box by unpluging from the wall outlet and wait for about 1 minute and pluging it back in. Make sure box or television is not in mute mode.
Dec 08, 2009 | HP PL4260N 42 in. Plasma HDTV
2001 Lincoln LS squells or squeeks when steering wheel is turned.
power steering unit probably going out !! Have you checked the fluid level in the power steering pump!!swampratt200!!AAAEEE!!!
Jul 21, 2009 | Lincoln Continental Cars & Trucks
Help to turn on
SINCE YOU JUST BOUGHT IT I WOULD TRY IT IN ANOTHER OUTLET IF IT DOES NOT WORK THEN,I WOULD IMMEDIATELY TAKE IT BACK TO WHERE I BOUGHT IT.I KNOW SOME T.V'S WILL ONLY CUT ON FROM THE REMOTE,SO I WOULD MAKE SURE YOU HAVE THE RIGHT REMOTE,CHECK TO MAKE SURE ALL BATTERIES INSTALLED PROPERLY.AND IF IT DOES NOT WORK THEN WHY SHOULD YOU TRY AND FIX SOMETHING THAT IS NEW
GOOD DAY
KZ
Feb 26, 2008 | Durabrand DU1901 TV
Televison & Video Logo
Top Televison & Video Experts
