Cd player cuts out after a while - Computers & Internet
    Master:
    Sergeant:
  • 482 Answers
Upgrade it.
Posted on Apr 13, 2008
My HD350 Technics audio set consistent of four Parts:ST tuner, SE amplifier, SL CD plager, RS cassetteplayer wicht are connected via a flat broad cable. It goes from tuner to cd to cassette. Now my cassete...
Please don't cut a cable, You won't be able to repair it. There must be a way to lose the cable without cutting. I forgot, but I will search around. When I find something I'll come back on this.
Jan 18, 2015 | Technics Audio Players & Recorders
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
I put a new cd player in and i cut the wiring harness now gauges dnt work
sounds as if you cut the wrong wire.... i would recommend taking the cd player out and trying to patch everything back up to original and maybe get someone to fit the cd player for you? hope this helps
Feb 26, 2011 | 2004 Chevrolet Blazer
Just moved into a house with wood floors. every time i walk past the cd player it skips. what is a cheap, easy, shock absorbing solution?
Go to a hardware store or crafts store and get a sheet of 1" or thicker foam rubber. It doesn't have to be very large as you're going to cut some 3" diameter circles (or squares) out of it for each of the four "legs" on the bottom of your CD player. Position them under the CD player and this should provide plenty of shock absorption.
Feb 20, 2010 | Audio Players & Recorders
My radio harness was cut and tring to install cd
okay you will need to hard wire it in the vehicle. so i will need to know what year make and model car you have?
Jan 31, 2010 | Clarion DXZ645MP CD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Kenwood KDC-322 volume cutting out
there buggers rewire the earth/ground
Jun 19, 2008 | Kenwood KDC-322 CD Player
Cuttinng out
Does it cut out when you are listening to the tuner as well as the cd player? If so, you have a bad connection somewhere. Sometimes the solder joints inside the radio can be cracked and will cut out when you hit bumps. May be a wire that is a little loose. Check all the wiring.
If it only cuts out when you are listening to the CD player, you may need the lens cleaned or the laser replaced. Sometimes the cd player cuts out because the unit has too much wiggle room and it bounces a little when you hit a bump causing the cd to skip or cut out. and there is always the dirty CD. Try cleaning the CD's with windex and a soft cloth like a bath towel. It works great for me and is cheap. Fingerprints can and will cause a cd player to skip.
Jun 07, 2008 | Pioneer DEH-P6800MP CD Player
Computers & Internet Logo
David Payne
David Payne
