Question about Grilling
Cant get the burners to stay lite.
We thought it was the regulater, but we replaced it and the burners still wont light! Only one burner lights up, and when we turn the other ones on, they all turn off!
  • 4 more comments
  • Anonymous Apr 17, 2008
    I am only able to light 2 at a time as soon as I try to light a third they all shut off and no gas is going anywhere.
    Thanks
  • reeveb Apr 19, 2008
    I have the EXACT same problem with my p3 ...really week gas/flame on one side and if you turn on botht eh flame is so weak they just blow out. I replaced the venturi tubes - cleaned the whole grill and had the gas station double check the propane tank. Everything checked out ok. I also tried the excercise of 'resetting the regulator' by taking the gas tank off and opening the burners to high whihc supposedly works. I am so frustrated.
    The only thing I haven't done is replace the regulator...but it sounds like you treid that.
  • Anonymous May 05, 2008
    Have the same problem on a five-burner. Called Charbroil and their fix worked for one lighting of the grill (disconnect grill from gas for 3-5 minutes). Now the problem is back and their fix doesn't work any more. Sounds like a design problem of some sort...
  • kvh2kids May 31, 2008
    Uuggh...I've had the same problems as described here -on our 5-burner elite. Gas wouldn't stay lit, cleaned the entire thing, worked once, then wouldn't work, then it wouldn't light at all. I called barbeques galore and they said I could either get service for $85 (?/hour) and parts or suggested I buy a new regulator, which we just did today. NOW we can't access the bolt to change it on our 2yr old model (new ones are accessible from the rear) and it looks like from what I read here, this regulator isn't even the solution. :(
  • jennagray Jun 13, 2008
    Same problem, has anyone fixed this?
  • Anonymous Jun 16, 2008
    I have a jenn-air 5 burner grille and have the same problem. I can only light two burners at a time. right side or left side. when i try to light the 3rd burner the burners shut down. It does not seam to be clogged lines because one side works or the other side works.
  • 36 Answers
Here is a few Ideas:
Burners will not light:
1.Gas injector not inserted in venturi tubes
2.Clogged gas injector
3.Obstruction in gas line.
4.Spider webs in venturi tubes.
5.Misalignment of collector box and burner
6.Out of gas
7.Dead battery
Posted on Apr 28, 2008
Spiders like to create little hidey webs in the tubes of propane grills and stoves.
Take it apart as much as you can and blow compressed air through all of the holes and apertures. You can either take it to the gas station and us the $.25 air machine or buy a can of compressed air at your computer store.
Posted on Apr 18, 2008
I have a coleman backhouse side solution grill. this grill is 3 years old. it has 3 burners and a deep fry on the left side. I can not get the burners to stay lit. I have removed the burners and blown air through them. I think it may be the valve, but when going on the internet i can not find any replacement parts for this grill. any help would be appreciated. email attylantz@yahoo.com thanks
Posted on Apr 23, 2008
Why burner on light on stove wont come off
After stove is turned off, the light stays on if burner still warm. If the burner never came on, then it needs to be replaced with new one.
Apr 26, 2014 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Pilot stays lite but the burner wont ignite propane unit
the gas is not coming out of the burner, probably due to rust clogging the holes.
Dec 04, 2009 | Water Heaters
Flame goes on than out and keeps doing that wont stay lit!!
I'm assuming you're referring to a gas burner that supplements the heat pump. If the burner lights at all, The ignition system is working. If you need to reset it for it to relight, I would suspect the thermocouple. It detects the flame to prevent gas from pouring out of an unlit burner. If it malfunctions, the control thinks the burner didn't light and shuts down for safety.
Nov 26, 2009 | Weather King 10AJA6001AH Air Conditioner
Kenmore 70 series gas dryer cycles a few times then stops
sounds like the boost and assist coils are overheating and getting week, it may be just the one, but i would replace both at the same time
doubt ignitor is your issure or regulator since thats really just an orrifice
Oct 04, 2009 | Kenmore 74602 Gas Dryer
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot light stays on but burner doesnt ignite
usually the small opening on the burner that 'points' to the pilot light will get clogged with cleaning soap or spills. Look carefully (the burner may be very easy to remove for inspection. There should be a small hole on the side pointing toward the location of the pilot light. It will be lower down than the main burner openings. Clean it out with a wooden toothpick.
Jun 19, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Main burner will not light. pilot has now gone out
shut off the gas at the gas **** and gas valve. the pilot tube is held in place by a 7/16 compression nut. remove it then remove the 2 screws for the thermopile "generator". follow the pilot tube and the pilot assembly should be held in by one or two screws. usually you don't have to remove the main burners. hopefully this helps
Jun 14, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Glas flow will almost shut down once i turn on the second burner
hi my name is mark, let me see if i understand your problem. you light the 1st burner and get a good flame. you light the 2nd burner with the 1st burner lite and it starves both burners of gas. if this grill is a lp grill and you have propane in the tank. the regulater is the problem.
Feb 22, 2009 | Kenmore 16228 Grill
Grilling Logo
773 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
