Question about Samsung HLR5667W 56" Rear Projection HDTV
Tv will not stay on for more than about 5 seconds
When i plug the power cord in, the tv automatically turns on. i dont have to press power or anything, it just turns on, makes the normal beeping noise that its turning on, the lamp light flashes a couple times, the picture comes on, works for about 3 seconds, then the screen freezes, stays frozen for a couple more seconds and then the tv shuts off, restarts and does the whole sequence over again. what could be causing this? i dont think its the bulb as the picture is very clear and bright when its on, but the tv will not stay on. the other thing that i noticed it is doing is throughout the whole process, anytime i press any button on the remote other than menu, the (TIMER) light on the power button lights up. any insight into this would be greatly appricated. thanks
  • 1 more comment
  • mauth Apr 27, 2008
    I don't even get 5 sec. Samsung HL-R5667W turning set on results in brief flash from "tiner" lamp followed by several flashes from "lamp" light then nothing. No picture or sound at any time.
  • Anonymous Jul 10, 2008
    I have the same problem tv turning on then screen freeze then off and repeats cycle. Havent found a solution yet either.
  • trforce Aug 30, 2008
    Same problem. We have had the set for about 2 years. The service guy said he thinks the board is bad and lightning may have struck. We are in Florida and have lightning all the time. I think it is a deffect after reading several post. $500 to $600 job. I will keep you informed.
    Novelist:
    Champion:
  • 203 Answers
It is normal for timer lite to blink when a remote command is sent. However, the problem you are having can be caused by several different things. I have had the same problem with my samsung dlp and have done the factory service for several years. First, you need to vacuum out all vent holes on the rear of the set. Then, remove the lamp cover, unscrew the screw holding the lamp in place and remove lamp. Do not touch glass. Look to see if filament is shattered. If not, firmly reinstall lamp and secure. Then reinstall lamp door making sure you engage door switch. Try set and see if this helps unless lamp was shattered. If not, replace lamp. Weather or not it is bad, you will need one sooner or later. Also, listen for a zing noise a few seconds after power is engaged. This is the color wheel which is another possible cause for this symptom. Truth is, almost any part in the set can cause this, but I gave you the most common things you can do by yourself to test this unit. Good luck, Russmann.
Posted on Jul 15, 2008
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Lg 42px-4dv/ea sustain pcb fails after 6 hrs running.
Try hard resetting;
NOTE:
Figure 1: Example of the reset button labeling on the LC2600N
7. Turn on the TV.
Jul 21, 2008 | Televison & Video
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
I have a 57" 57F500. It will not stay on
Resetting the TV
NOTE:
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
Hope it may help you;
Regards;
VOTIT
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Black Spots
Resetting the TV
NOTE:
7. Turn on the TV.
Regards,
VOTIT
Sep 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Panasonic pt-53wX42, power wont stay on. Turn on, no picture then it will turn off by itself after 5 seconds. The red power button will flash on and off until I unplug unit and start the whole process...
I'm no expert, but I'd start by taking a "VERY GOOD LOOK" w/magnifing glass if possible , @ UR Wall Outlet Power Cord. Change to different wall outlet. Ur Power Cord "should" just pull right out of the back of your TV. If nothing in those places, then take off back panel (or part where power cord plugs into TV & AGAIN inspect area around where power cord attached for, yeah, that's right, the dreaded black area around plug-in area. Maybe it's just a bent prong. Any other funny things going on that U didn't mention here? Good Luck Leonard aka quikstudy@cox.net
Jul 23, 2008 | Televison & Video
TV turns off
It sounds like you might either have a bad power cord or you might have an over heating issue. Some times the TV will automatically shut off if it senses a fan issue or it starts to overheat. What technology is your set? DLP, LCOS, DILA...? If its under warranty I'd suggest to get someone out asap to take a look at it.
Sep 13, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Samsung HLR5667W 56" Rear Projection HDTV Logo
189 people viewed this question
cce772000
Level 1 Expert
