Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Broke screens! my friend decided to put his head through my dlp. i just want to buy the two screens that display the picture. how much are they and do i need to go to panasonic?
  • pst2868 May 11, 2010
    contact me at pst2868@aol.com
  • 50 Answers
How much are you willing to pay?
Posted on Mar 10, 2010
Samsung HLR DLP TV with white lines from top to bottom. First had no picture, bulb is 10 months new, I replaced the color wheel, and just put in a used DLP Chip. Picture came back perfect, but these w
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 18, 2017 | Samsung Televison & Video
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
Best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Oct 28, 2011 | Televison & Video
I need replacement screens for a Mitsubishi wd-73733 tv. It was damaged in transit. The rest of the set is fine, but I have to track down the replacement screens. Any ideas out there? Thanks!
Best place would be from Mitsubishi, although the screen might cost more than the TV is worth fixing because you're bound to have to have it installed by a TV repairman. It might be a god send that it was broke DLP is a technology that is being phased out by the very company that made it big, You can get many LED or Plasma TV's for around the same size and fair price at your local Best Buy.
May 03, 2011 | Mitsubishi WD-73733 73" HDTV
My Samsung DLP hln567w tv has NO picture on all
If the Lamp ignites and stays lit, but screen is completely black, not even the on screen display, then it is likely a bad DMD board.
If the lamp ignites and then turns off after a couple seconds then it is likely the color wheel is seized.
If the lamp never fires, but the TV clicks a bunch of times, then it could be a bad Ballast or the Lamp itself.
Sep 18, 2009 | Samsung DLP HL-P5663W 56" TV
Vertical lines on screen. Can't see picture at
It sounds like you need a new screen.
Buy one on Ebay for 20 Euro (inclusive of postage)
youtube.com has great videos of how to change a screen.
You will need a tweezers and very small "philips" (cross/plus head) screwdriver.
Make sure the screwdriver has magnets....so that you dont lose some screws....they are tiny.
If you buy a replacement "LCD Screen Display" on Ebay then usually all the tools you need are included. (I just checked).
I also have just replaced my screen....screen was damaged...LCD leaked and lots of vertical lines on a now only WHITE screen.
Camera works fine now.
Check to see if the camera is still working.
Try taking some pictures....and then put the SD-card into your computer to see if the pictures are being taken.
Jul 14, 2009 | Kodak EasyShare V570 Digital Camera
My Samsung HLN5065W started to freeze to a black and white
I have a problem with my HLN 5065W Samsung DLP that 3 other folks have and no solution. After the set is on from 5 minutes to 6 hours, the screen will freeze in black and white, I can turn it off for 5 minutes and it will display a good picture again. Sometimes the screen will just go dark blue, TV has to be cycled on/off to get the display back. This problem is getting worse, started as once a month, now 3-5 times a day. I have a tech background and can read a schematic, HELP.
Mar 01, 2009 | Samsung HLN5065W 50" Rear Projection...
Displays picture in black and white
This must be a DLP (I hate DLP Personally). What most likely happened is that the color wheel got stuck or broke. Remove the bulb, you will be able to see the color wheel. Don't touch it with your hand, see if you can move it with a tooth pick or something. Then try turning it on with the bulb out to see if it moves.
Apr 23, 2008 | Dell 3300MP Multimedia Projector
Broken screen
Replace it for new and get the friend[?] to put their hand in their pocket
Jan 17, 2008 | Olympus FE-230 Digital Camera
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
