Question about Dishwashers
Re; Smeg DWD612CSS dishwasher. Please help. On setting our dishwasher to operate overnight, we were awoken by a loud bang only to find a strong rubber burning smell and the trip had blown. After investigating we found that the part no DWF 409 interface filter required replacing which we have done. Now however the dishwasher runs to the middle of its cycle and stops. The troubleshooting page of the manual tells us code E3 applies i.e.first 2 phase lights are lit and states "The appliance is not able to pump out water", but the machine is empty of water. It would also appear to be cold inside so we assume that it has not been able to heat the water during the wash. Any ideas to help with this problem will be very gratefully recieved. Pete
  • jo crabb Apr 13, 2008
    Thank you.
    Just to clarify we have done it correctly, am I right to assume that the red wire in the appliance connects to the brown live/phase line in from mains supply? Also that the white wire in the appliance connects to the blue neutral in from mains supply? These connections terminated on the interface filter.
    Very grateful jo
  • jo crabb Apr 18, 2008
    Yes, pleased to report that we have found a loose wire and now that it is connected properly, the dishwasher is working fine.
    Many thanks
    Jo
  • 3,037 Answers
I would first look for anything that may be stuck anywhere in the machine that may be causing it to come up with an error. Possibly something that was in the dishwasher is making it think it can pump out the water even though it is draining.
I think that the code E3 stands for a heating issue so I would have a look at those components in your diswasher and see if they are working.
Let me know what you find when checking it and we can go from there to fix your problem.
Good luck and be safe when working on it.
Posted on Apr 13, 2008
  • Benjamin Patri
    Benjamin Patri Apr 14, 2008
    yes, that should be correct
  • Benjamin Patri
    Benjamin Patri Apr 18, 2008
    I am glad that you were able to solve the problem. Usually they are just simple little things.
    Thank you for using Fixya and please don't forget to rate this solution.
    Have a Good Day!
    Brigadier General:
  • Dishwashers Master
  • 3,614 Answers
The code means " Remote controller comms error. Check wired correctly,"
Thanks
  • micromaster
    micromaster Apr 16, 2008
    Any development about the project there..?
  • micromaster
    micromaster Apr 18, 2008
    well i think i deserve a rate in here Jo..
Smeg dwf 409 ss went bang
is the power light on the board or a separate indicator?
were did the current go when the capacitor in the filter blew? probably into the board......
Oct 16, 2013 | Smeg Dishwashers
Hello I got a Smeg DD612SCA7 its blows circuit breaker and makes a loud bang every time I plug it in and then a burning smell comes from inside. Any idea? Paul
You need to make sure the unit's voltage requirement matches what it is being fed to it and that the power connections are correct. You are describing a dead-short situation and will likely have a serious fire condition if you continue to attempt operation. If you are not sure, please consult an experienced electrician to help sort out your wiring. Good luck!
Jun 04, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Smeg dishwasher E1 error code, not filling up
Hi!
here are manuals to the number of SMEG dishwashers.
Hope you could find there your device and the "troubleshooting" part of it would help you!
https://manualsbrain.com/en/brands/smeg/dishwashers
Dec 07, 2017 | Smeg Dishwashers
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
The buzz that you hear is the water line solenoid. It probably is not opening up to let the water through. You should replace this solenoid and it will fix your problem as long as you have water coming up to the diswasher's solenoid valve.
Dec 03, 2008 | Smeg 18 in. DWF409WH Slim-Line...
Dishwasher Smeg DWD409SS
Hi
Please go to www.smeg-service.co.uk/support
Jun 22, 2008 | Smeg 18 in. DWD409SS Built-in Dishwasher
Timer Knob Smegdishwasher sa 620x
I have this same model Smeg dishwasher. 1 = Soak - pans and dishes awaiting completion of the load. 2 = Strong - Very dirty pans and dishes dirt dried on. 3 = Normal - Normally dirty pans and dishes. 4 = Rinse - Dishes requiring "refreshing". If you would like a full copy of the user manual, send your address to "brockjack@g-node.com.au" and I will photocopy our manual for you.
Oct 06, 2007 | Smeg CSU2001 Built-in Dishwasher
It's stuck on Bio...
Here is the link to the user manual, hopefully this solves your problem else please ask again; http://www.smegtech.com/site/smeg/pdf_libretti/19590097802-GB.pdf Hope this helps :)
Jun 25, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Apr 23, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
308 people viewed this question
Top Dishwashers Experts
