Question about Karcher 2500 PSI Pressure Washer
Stalling Engine starts good cold, when it gets warm and you pull the trigger it dies. And it will not restart when it is hot.
    Genius:
  • 1,554 Answers
Likely you air to fuel ratio is too lean, runs mean and hot but under load dies. then floods the carb.
when it happens pull the plug ,
kill engine :
is there a lot of gas or none.
remove the filter and watch the action of the carb does it open and close easily is the filter clean.
try supplying it more gas turn the gas supply screw 1/2 CCW and see if it will stay running, if not add more.
( NOT the idle screw on the carb side w/spring )
By the way did a bit of water come out if not the clutch/pump may be binding or stuck with soap goop.back flush with hot water.
Posted on Apr 13, 2008
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
It will crank and run good for 10 minutes and shut off. Once it shuts off when you restart it, it will only run for a couple of minutes and shut off again ?
I would start by getting a can of carburetor cleaner and have it 'at the ready' and try the 'start, run stall, start run stall' operation again. Only THIS time, once the engine begins to stall, give it a couple of quick shots of the cleaner into the air filter to see if it stays running on the cleaner.
If it does, then it's still a fuel problem. If it doesn't, then it probably an ignition problem. I would be sort of leaning towards the ignition coil getting weak. The reason I'm saying that is your statement about it running (I'm assuming cold start) for at first, 10 minutes then it stalls. Start it again and it runs for a couple of minutes and stalls again.
This could possibly be from the coil getting warm/hot and not producing the needed spark. After a 10 minute run it simply gets too hot and stalls the engine. After the next restart, the coil is already warm from the engine and so it don't take as long for the coil to get hot and stall the engine again.
Hope this makes sense and helps you out.
Apr 25, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Dies when I first start have to restart a few times and dies at stop light unless it gets a little gas
This is usually a problem caused by a bad water temperature sensor. There are usually 2 sensors with one working the temperature gauge and the second working engine controls.
The "cold start" sequence is similar to a choke in old cars. It needs the signal from the water sensor to trigger the cold start sequence. The cold start sequence enriches the fuel charge, adjusts timing, and increases idle speed until the engine gets a little warm.
Now if stalling when warm, you have other issues. Manifold runners are a problem on some engines.
Feb 12, 2014 | 1999 Ford Taurus
No check engine, stalls cold start, dies after warm
If you haven't done it already you might have them run it for codes to see if it is showing any. Autozone does it for free too.
Dec 23, 2013 | Hyundai Santa Fe Cars & Trucks
1996 mercedes c280 dies when put in drive
Engine stalls or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 15, 2012 | 1996 Mercedes-Benz C-Class
Jeep liberty 2002 3.7when starting cold starts-stalls unitl hot
Check the temperature sensor feeding the ECU and O2 sensor.
Apr 12, 2010 | 2002 Jeep Liberty
Jeep grand cherokee stalls after warming up
You need to check components again when the engine is hot and in no-start condition, otherwise, you will get bad info...obviously whichever part is doing this works fine cold. ones that react most to heat are crank pickup, ignition coil and the fuel pump.(bad ones get hot and bind up)
Jun 07, 2009 | 1993 Jeep Grand Cherokee
2001 Explorer 4.0 engine stalls
probly o2 sensor, cus when cold the computer does not take into account what the o2 sensor is relaying, but when it is hot it does, try unplugging it when hot and see how it runs, it will run rich but should run ok, if it does its the o2 sensor
Jan 28, 2009 | Nissan Frontier Cars & Trucks
Karcher 2500 PSI Pressure Washer Logo
478 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
