Question about NEC VT460 Multimedia Projector
NEC VT 460 LCD Panels & Fly Eye Lens
I need to know how to get to the LCD Panels and Fly Eye Lens so I can clean them to hopefully stop a ghosting problems I have with my projector. thanks.
  • This is a pseudonym May 11, 2010
    So what IS causing it?
    I'm at my workplace right now with the guts of one open on my desk and I'm damned if I can figure it out. We have a lot of these doing a similar thing, and the official service guy wants more than they're worth to repair them... the lens seems good, the rest of the light path is ok so far as i can tell (no burns or obviously displaced parts), the only really inscrutiable part is the tightly screwed together LCD block that doesn't seem to have any adjusters on it.
    (Got one that's had its PSU fail, so while swapping in the power supply from another that runs but has a SERIOUS shadowing problem I thought I may as well pull it apart and take a look at what's in there)
  • 563 Answers
HI there
Firstly this ghosting image will NEVER be caused by your LCD's , so do not take them out.
Have you tried using a different cable ?
If you have and the problem still occurs , you will have to look at replacing the Mainboard.
Posted on Apr 15, 2008
GREEN GLOW on NEC VT 770 projector
That will be a worn or damaged green LCD unit. If still available, extremely expensive.
Jun 22, 2017 | NEC VT770 Multimedia Projector
MT850 has double image or ghost image, how do you fix that?
one of the lcd panels or more then just one r bad.
cost of thuse lcd panels r more then what this old projector worth
Jan 20, 2010 | NEC MT850, MT1050, MT1055, MT1056...
We have Chrstie 2 LX100s, recently one has a warmer color
reset the settings to factory default. if that doesn't change anything, clean the dust out of the projector and check the second diffuser lens (fly-eye) next to the lens. also check the polarizers next to the lcd panels. they tend to fry due to excessive dust and heat.
Oct 23, 2009 | Christie RoadRunner LX100 Multimedia...
NEC VT 480, replaced new lamp ,still low brightness.
if you remove the lamp, inside the lamp housing you will see a refraction (fly-eye) lens. these evenly distribute the lamp light. the one on the other side from the one you see (there are always 2 lenses) is probably burnt and needs replacing (a common problem with lcd projectors). you will have to send it in to nec. in many of their projectors, both lenses are in one assembly.
Sep 11, 2009 | NEC VT595 LCD Projector
The powerlite S1 projector has a green tint.
check the fly eye lens and then Lamp unit. Service and check the LCD panels.
Jan 12, 2009 | Epson - PowerLite S1+ Multimedia Projector
Projector problem
if it's an lcd, the fly-eye lens might be burnt. return it.
Nov 29, 2008 | Office Equipment & Supplies
Problem with image from LCD
No, If the problem comes with connecting the signal, then it could be RGB.
if this is coming with all time then check LCD panels and Fly-eye lens.
Last thing is lamp unit.
viren
Sep 19, 2008 | Toshiba TLP-S10 Multimedia Projector
Double image
Use this link to get company support:
http://www.necvisualsystems.com/SupportCenter/SupportTracker/
Apr 13, 2008 | NEC MultiSync MT840 Multimedia Projector
Fly Eye lens and LCD panels
Fly-eye lens is just next after the lamp.
Apr 05, 2008 | NEC VT460 Multimedia Projector
NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Dec 16, 2007 | NEC VT460 Multimedia Projector
NEC VT460 Multimedia Projector Logo
576 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
