Question about Hotpoint WD62 Front Load Washer / Dryer
Washer full of water?!
we just washed some clothes and while it was washing it made loud noises as if something was somewhere in the way, afterwards we had to find out clothes soaked. the water was not pumped out of the machine, we washed our clothes again but no difference to the first wash, the mashine was full of water.
what can you advice?
Thanks Franzi & Elsie
  • 247 Answers
The most likely culprit here is a the pump, which may either be blocked, or broken.
You should be able to get access to the inside of the pump through a small hatch on the front panel of the machine at floor level. Beware - as you open this, really quite a lot of water is going to come out, so you'll need tomething to catch it, and you may need to shut the cover a few times if your container fills up before the machine is empty.
Once you've got into this space, remove all the loose coins which have accumulated there. If you think you found enough to block the pump and stop it working, put things back together and see if the machine is fixed.
If not, turn off the cold water supply, and run the machine in tumble-dry mode for a few seconds at a time while watching the pump impeller (looks like little fan) in the back of this cavity.
If it doesn't start whizzing round of it's own accord every time, then you need a new pump motor. These are cheap, readily available on the net, and straightforward to fit.
If the pump appears to start and run OK, then check for kinks and blockages in the hose that goes from the drum down to the pump, and in the drain hose that goes from the pump out the back of the machine. Finally, make sure that where the drain hose plugs into the standpipe (of whatever fitting is used in your part of the world to connect to the domestic drains), air can get in freely.
Posted on Apr 13, 2008
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes washer will not finish spin cycle.
maybe something in the drain pump take bottom panel remove pump by turning filter and remove debris dont forget to vacuum out water from drain hose or your gonna get really wet.
Feb 21, 2010 | Washing Machines
When spinning very loud before very silent
Since you say that before it was silent and these days you see loud noise while spinning I would first recomend to see the correct balance of the cloth you put in. Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Also Either you put something like a screw or a nail in with the washing, which will travel through the drum holes and scrape on the fixed drum. Check in case anything is left in a hole.
Or the bearing which the drum rotates on is shot. If you lift the front edge of the drum up and down by hand you may find excessive play due to bearing wear (a small amount of movement is normal), or rotate it by hand to confirm the noise.
Bearing replacement is acually quite easy for an average DIY person. You can get the bearing and water seal from either the maker or a good w/m spares shop (yellow pages). The tools needed are crosspoint screwdriver, and a socket set.
Thanks for contacting Fixya.
Sep 28, 2009 | Zanussi FJS1225W Front Load Washer
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
My washer was tilted forward and now it is making a strange noise
the wash arm may be out of alignment now you might see if something fell into the bottom of the machine.
Jan 08, 2009 | Washing Machines
Washer fills with water but will not agitate to wash the clothes.
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Spin cycle noise problems
It is likely that you have an unbalanced load. Try spinning the machine with only water in it. If there are no noises now, you will need to re-distribute the load. We clothes are heavy!!
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Hotpoint WD62 Front Load Washer / Dryer Logo
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
