Question about HP Color LaserJet 2600n Printer
Getting a squeel from the printer when it runs
Is there any place where oil needs to be applied getting a high pitched sq2ueel when the printer runs
  • 300 Answers
Use vasaline on plastic gears not oil, where is the noise coming from front, back ????
Posted on May 16, 2008
Clicking noise when applying the brakes on a 2002 cadillac seville
If there isn't a high pitch squeel when applying breaks, then your pads/shoes are worn down to the rivits. If in the rear, could be defective hardware in the brake drum/brake assembly.
Jan 16, 2013 | 2003 Cadillac Seville
Hyundai accent 2005 when starting up the vechile and driving there is a constant ugly sound coming from the front passenger side wheel and when applying the brakes on there is a high pitch squeel
That screeching sound is a warning that your brake pads are worn down to the point where they should be immediately replaced. If you do not replace the pads, you'll score the rotor and incur an additional expense. Remember to replace the brake pads on both sides, i.e., driver and passenger side.
May 01, 2012 | 2005 Hyundai Accent
2003 Lexus es300 has high pitch squeel in front driver side tire, stops when brakes are applied or when I turn the wheel
u need front brake pads...the noise u hear is a warning sensor that is on the brake pad...it will touch the brake rotor when the brake pads r getting very low an about ready to start grinding into the brake rotors
Jul 16, 2011 | 2003 Lexus ES 300
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Alarm comes on while driving once you apply the brake it stops
this alarm your speaking of, does it sound like a high pitched squeel?
if so, your front brake pads are very thin and that the "screamer" GM has on all of its front disc brake pads. Thats to get your attention that something needs to be looked at.
Oct 12, 2009 | 2003 GMC Sierra 1500
Valve cover building up excessive vacuum on 97 318ti
The pcv control unit is bad. Its a big black plastic unit under the intake.
Apr 05, 2009 | 1997 BMW 318
Black screen with high pitch squeel
Hi...there,
YEah...sure! You need to replaced or repaired your backlight inverter....
Oct 11, 2008 | Gateway FPD2275W LCD Monitor
Akai LCT2662
You're getting some feedback on the secondary transformer - most likely... Try to isolate where the pitch is coming from and see if it's harmonic. May just need to be glued down or have some leverage place against it...
Bill
Apr 01, 2008 | Akai LCT2662 Television
HP Color LaserJet 2600n Printer Logo
146 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
