Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Television wont power on
I pressed the power on button on the remote and the TV wont turn on.. So i tried the power button on the unit,,The tv still wont turn on...I have a sony model KP 51 ws520 television..It was made in 2004.
  • sweetcarie Apr 24, 2008
    Same problem the LED light blinks nine times then pauses. Tv wont turn on.
  • Sony Master
  • 8,617 Answers
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Posted on Apr 13, 2008
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
I neid go know how to reprogram one of the controls for the tv in a room but i lost the control for the tv in my living room, in the living room i have the cable box.
jc4lifes3as
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
2. Press and hold the TV Power button for three seconds until the LED flashes.
4. Press OK. Note: The LED will flash three times.
Power Scan:
Remote: Basic Remote (Television Only)
3. Press and release the TV Power button.
4. Press and release the Up or Down Arrow on the remote until the television turns off.
5. After the television turns off, press and release the OK button.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network"
Apr 16, 2011 | DISH Network IR Remote Control
Remote not active with the tv
unessr
Program to TV:
  • Remotes: Basic (Television Only)
Power Scan:
  • Remote: Basic Remote (Television Only)
I hope this helps.
Ray Calo
DISH Network
My remote wont work
sorrycory27
I'm not sure what the remote is not operating on: TV or receiver? I have provided instructions on how to program the remote to your TV or readdress the remote to your receiver.
Readdress remote to receiver:
Remote: All Other Remotes
  1. Go to System Info screen
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Program remote to TV:
  2. Press and Hold the TV Power button for three seconds until the LED flashes
If you have any other problems or questions, please post to this site.
Ray Calo
DISH Network
Nov 14, 2010 | DISH Network IR Remote Control
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Oct 08, 2009 | Televison & Video
Cant get the remote to turn tv on off or channels
hmmm.. Do you have another remote that will operate that tv, try that remote and see if it will turn on and off the tv. IF you bought this new remote because your old one quit working it may be the tv and not the remote. If you have a camera phone you can check your old remote. Turn on your camera and aim the remote at your phone, look at the picture on the phone and press the power button on the remote, you shuld see the front of the remote flash, if you do then it is the tv causing your issue.
Sep 02, 2009 | Philips Magnavox 20MT133S 20" TV
Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Feb 01, 2009 | Hitachi 50FX30B 50" Rear Projection...
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
On/off button flashes green, unit will not turn on manually or with remote
PRESS THE TV BUTTON OF YOUR REMOTE CONTROL FOR FIVE SECONDS AND YOUR TV WILL TURN ON.
Sep 25, 2006 | RCA T19064 19 in. Combo
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
309 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
