Monitor My monitor starts blinking and a black line appears and the in a short time the monitor goes blank. The power light keeps blinking and monitor does not shut off.
  • Anonymous Mar 25, 2014
    monitor will start up and then shoe eco start but then screen goes black and monitor light blinks
    Scholar:
  • 160 Answers
It may be the Monitor Problem or Re-Install the vga drivers with the cd you get while buying the motherboard.
If the problem continues re-install the OS witht the latest service packs available
Let me know if your problem is solved and rate me as FIXYA!
Posted on Apr 15, 2008
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
Monitor power light blinks, then goes out. PC screen goes black.
Unplugging the power cord repeatedly is not a good idea! I hope this helps: 1- After you get a picture, go to "Device manager" (Click on Start-Programs-settings-device manager) and make sure that there is not question or an exclamation mark next to Monitors. If that is the case you might need to reinstall the driver! 2- Make sure that your video card is not faulty by hooking up a different monitor and see if it is working ok. If you still have the same problem, then you need to replace the video card. 3- Check all cables and power cords and make sure that there's good connectivity on all ends (before powering up the machine) and that there are no nicks or cuts. If possible try replacing the monitor's data cable as well. Good luck
Apr 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Lg w1934-bn blank screen after start up, power light on . same problem occurs on different computers used.
Reason 1: Wetness The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
i think this will help.
please rate my solution.
have a nice day.
Jul 05, 2009 | ViewSonic 17" 1280x1024 TFT-LCD/ Speaker...
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
try this.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Computers & Internet Logo
745 people viewed this question
David Payne
David Payne
