Oily residue under machine
We have a GE washing machine Model # WWA7070 Gal WN and have noticed an oily residue under the machine
  • MH56 Apr 13, 2008
    Quick response with the understanding of what the problem is.
    Thanks for the help
    Genius:
  • 1,073 Answers
It is coming from the transmission seal the part number is wh8x281 it is located behind the transmission pulley, remove the pulley and remove the old seal and intall the new one
Posted on Apr 13, 2008
LG Tromm WM2233HW- Problem with oily residue on clothes
Use warm water and powdered detergent. Leave the door open in between cycles and it will be clean as a whistle in a week... Powdered detergent is HE also, don't believe the hype, stop wasting your money on useless chemicals to rinse away the garbage chemical soaps you are being ripped-off by... Hopefully, the liquid detergent hasn't corroded the washtub and drive shaft so badly it is oozing slime!
Jul 26, 2016 | LG Washing Machines
I have an oily residue in my washer machine and my clothes how do I fix it
If its not from heavily soiled clothes like garage overalls then I would bet the drum bearing seal has gone and bearing grease is contaminating your wash. See if there is any water dripping underneath from the seal and if this seems to fit with your situation then you need a good DIY fixer or appliance engineer to have a look at it.
Aug 01, 2014 | GE WSLS1500JWW 26" Top Loader Washer with...
My GE washer is leaving a brown oily residue inside the drum after washes.
I amj thinking that you use soap powder in your washing machine. If that is the case what you are expericing is the accumulated powder residue under the agitator breaking away and marking the clothes. Re move the agitator and clead all the gunk out of the machine including a water recycling(saver ) hoses. Washing powder is 90% clay that is used to carry the active ingredaient and is never completely flushed in the rinse cycle. Ity also cause a deteriation of the hoses and pumpseal. When you have cleaned out the machine I recommend you only use liquid detergents as they are more effective and don't leave the residue.
Mar 11, 2013 | Washing Machines
Washing machine noise
sounds like gear box is dry if you noticed any oily spots on floor under machine
Mar 08, 2013 | Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
Washer depositing oily stains on clothing HELP
Best way is the old fashioned way. Purchase some soda chrystals and pop them in ur drw. The same amount as you would normally use in detergent powder. Then put the washer on the hottest setting and wash the machine out. Do not put any clothes in the washer at the same time though. This will clean the washer it may take a couple of attempts to clean but doing this once a month will keep on top of it.
Hope this helps
Mar 28, 2010 | Whirlpool Washing Machines
My washing machine is ruining our clothes
The oil from the bearings is leaking. Maybe (not sure about this) the bearings are breaking.
This issue requires major repair, so you may need to contact a service technician. If the appliance still under warranty, contact the manufacturer so they can assist you with the repairs.
Aug 31, 2009 | Washing Machines
Greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
Jul 21, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
