Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Reformatting. I have a Sandisk Cluster Micro 4GB and it only shows 194.2 MB's available. The only files on the device is the LaunchU3.exe file. I would like to reformat but I don't know how that works on my iMac. Can you help? Thank you, Allan broha6197@earthlink.net
    Scholar:
  • 75 Answers
you can Format your drive on a Windows machine as "FAT32" and it will be usable both under Mac OS X and Windows. the only thing to make note of is there are some limitations on the FAT32 format, like the 4GB filesize limit and certain naming restrictions.
You can reformat your drive by opening Disk Utility and then reformatting it using that application. in Mac OS X
- In Disk Utility, select the disk.
- Click Erase.
- Choose format from the Volume Format pop-up menu
(select the windows based format).
- Type a name for the disk or volume.
- Click Erase.
- You can use the drive on both the mac and a PC by choosing MS-DOS from the Disk Utility application when you're about to reformat.
Posted on Apr 13, 2008
I have files backed up on a Cruisersyc thumbdrive from and old computer. Currently running Windows 7 and cannot run the LaunchU3.exe file.
You might have scan or let the windows 7 checked your thumbdrive that might be the cause that the *.exe file is destroyed or scan and fix by an antivirus software. Also the exe file may not be compatible with the windows 7. Try searching a Launchu3.exe compatible for windows 7 if unable to, manually copy the files and paste it to your new computer
Sep 21, 2011 | Computers & Internet
I have a sandisk 8gb usb stick, I am tryind to copy files from windows xp to it but cant, i keep getting file not specified error. I can copy over small files on to it but nothing big. I know the stick is...
You need to re-format your Flash Drive. The default is FAT32 which only allows files of up to 4GB to be transfered. If you reformat to NTFS, ANY size file can be copied to your FLASH DRIVE.
WARNING ! ! By reformatting, you will loose ALL your data on your Flash Drive. Good Luck
Dec 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 4GB flash drive is empty, but only shows 51.8 MB of space left. How do I reformat, or restore the 4GB of space. The drive is a 2007 - if that matters. ** I am a MAC User.
This is a known issue with mac. If you have a windows based pc, plug the usb there and delete all the files. You will be surprised to see that there are remnant files in there from mac.
Nov 28, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My flash drive 16 gb sandisk cruzer u3. when i insert in Laptop it opens but file not showing. showing run launchu3.exe. how can i get launchu3.exe? i checked prpperties all file inside but not...
I have the very same flash drive.
The file you refer to "launck3.exe" is a file compression utility from Sandisk. It works well but I don't use it. I placed the drive into a USB slot and chose "open folder" in the options not "auto run". I then mad a new folder called "old cruzer" and moved all of the files in the root of the flash drive, to it. Leaving an nice empty drive to copy and paste to.
I hope that helps.
Oct 22, 2010 | Computers & Internet
SanDisk Cruzer Micro 4GB USB plugged it, light on, but shows an empty file in windows with capacity of 0bytes Also shows a CD drive (the one that U3 runs) which says nothing is in disk drive.
It is likely an issue with the filesystem. The FAT filesystem gets easily corrupted. If that's the case, reformatting it with FAT32 should help. But remember - reformatting erases all the data, so don't do it if you have anything important on the drive!
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
USB with no files says it's full (Mac computer)
I had a similar problem.  There are hidden files taking up your space.  You can clear this by using disk utilities and clearing the drive. Takes less than five minutes.  Good luck
Aug 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do i use it?
XP Machine (3 ways to access your drive)
1. Place the flash drive into your usb port. You might get a autoplay window to open up. You will see Install or run program (Run launchu3.exe). Click on this which will open up the lauch pad. Once the launch pad has opened you can click on the launch pad in the tray and it will open up the removable disk.
2. Right click on your start button. Click explorer this will open up a menu of your drives. Click on the one that shows removable drive. This will open up the drive and you can now start moving files into this drive.
3. Double click on my computer located on your desktop. This will open up a menu of drives. Click the drive marked as removable drive. This will open up the drive and you can now start moving files into the drive.
Vista Machine (3 ways to access your drive)
1. Plug in the flash drive. The autoplay will open up. Click on the launchU3.exe which will open up the launch pad. Once the launch pad you can click on the launchpad in the tray and click on the removable drive.
2. When the autoplay comes up you can click on the Open Folders to view files. This will open up the drive.
3. Click on the start button menu then click on Computer. Then double click on the drive marked as Removable drive.
Jul 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do i set up the password protect thing on my cruzer micro 4 GB ... please
Hi!
Plug your flash drive in and launch the .exe file that you will find there. It's probably called launchu3. Once you do that, then you will get a red box on the bottom right of your screen with the Cruzer name on it. Click on that, and you will find the "Security" section. The password setup is in that.
Jan 23, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisck cruzre 2.0 GB
DOWNLOAD CCLEANER FROM DOWNLOAD .COM AND RUN THE MENU WHICH SHOWS START UP FILES DELETE THIS ENTRY.. YOUR PROBLEM IS SOLVED
ANOTHER METHOD.
GO IN START UP MENU IN START---- PROGRAM FILES----
DELETE THIS ENTRY
Jul 26, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
284 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
