Question about Breadman TR2200C Ultimate Bread Maker
I have a Breadman Ultmate TR2200C breadmaker and it turns on just fine, however, the kneading paddle doesn’t “engage”. It makes a noise like it wants to, but nothing moves.
  • mudslideslim May 20, 2008
    My pan rides up and makes a racket. I have had to hold it down while it is keading, but it rides up on punch down. I have found no sollution, only began this after 10 loaves or so.
  • Anonymous May 06, 2009
    I have had the same problem twice: once soon after I purchased it (2004) and last month (2009). The first time when this happened, I called the customer service and it was only several things she told me to follow over the phone to fix it. No opening the bottom if I remember right. However when I called the same customer service phone number last month, they were not helpful at all. They would not try much (just told me to press the reset button and unplug, which did not even reset the machine), then no other help. I wish I made notes how the customer service directed me to solve the problem at the first time.
  • 25 Answers
2 solutions 1st is the belt on the bottom eother slipped off or broke.\
Remove the bottom cover 2 screws have special screws.
You can get the security bit at harborfreight.com.
Then check the belt.
Also check to make sure the passle shaft is not frozen. See pther cure on how to do this.
The pan jumps either because the shaft is frozen or the side clips that hold the pan are not locking you must bend them to hold the pan if they are too tight the pan is hard to remove.
This to me is not as good as a design as the twist lock on other bread machines.
Posted on Jul 24, 2008
I need a Kneading Paddle for my Breadman Ultra bread machine the Model # isTR700/600a
You may be able to order a replacement online from this site:
http://www.directpartsandproducts.com/bread-makers-tr700c-c-61_129_837_838_855.html
Recommend you check with the supplier to verify that the available paddle for the TR700C also fits your TR700/600a.
Thank you for using FixYa!
Jul 27, 2011 | Breadman TR2200C Ultimate Bread Maker
The device on the bottom of the bread pan appears to be locked and will not turn to knead the dough. Is there anything I can do? It worked fine the last time I used it.
The synthetic seal around the shaft which DRIVES the paddle is fried.
I need a replacement to fit on the shaft OR if necessary 2 new shafts with NEW seals
Feb 28, 2011 | Breadman TR2200C Ultimate Bread Maker
Will not knead the dough paddle dosen't move--you can move by hand it is not stuck
If motor is still working ok, it is probably a bad belt inside the machine that turns the padde.
Dec 27, 2009 | Breadman TR2200C Ultimate Bread Maker
My Breadman bread maker is broken. The pan jumps
It is likely that, due to a poor design the contact between the paddle traction and the machine is worn out.. Check it and you will see that the bare metal is shiny there in the two bumps in the rotating plate in the machine.
I used a dremel-like rotary tool to grind the contacting part so that the contact between the machine and the paddle traction is orthogonal.
Worked fine for me.
Regards
Nov 16, 2009 | Breadman TR2200C Ultimate Bread Maker
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Need a paddle for the breadman TR2200C
HI
You need to contact these people
https://secure.prodregister.com/prodprotect/applica/bm.shtml
The phone number for spares is here
Rob
Feb 10, 2009 | Breadman TR2200C Ultimate Bread Maker
Kneading
Check your measurements.
Sounds like operator error.
Dec 12, 2006 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
201 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
