Question about HP OfficeJet 7310 All-In-One InkJet Printer
Error message appears when powered on
As soon as i plug in my printer, it starts up and makes two noises then goes to a blue screen that says "Error: 0x88ga789e" .
It wont do anything and just stays at that screen unless i unplug it or hit the power button
I have a tear in the alignment of the color cartridge inside the computer, how do i replace the part
Posted on Apr 24, 2008
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    What is solution of error oxd05d010d
    Hi
    This error means there is an internal error condition. To resolve this error remove the cartridges from your printer. Now wait for message "Insert the cartridges' to appear on the printer, as soon as the message appears disconnect the power cord from back of the printer. (Restart the printer if message doesn't appear) Now wait for a minute and plug back the power cord, if doesn't turns on itself then press the power button.
    Insert the cartridges and check whether you are still getting the same error. If you are still getting the same error then try pressing # and 9 key simultaneously to reset the printer, wait for a while to let the printer complete the reset.
    Daniel Scott
    Jun 19, 2010 | HP Officejet 5610 All-In-One InkJet...
    HP Premium C309 All-in-One Printer error message "C2FE0065"
    I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
    1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
    I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
    Jan 08, 2010 | HP Photosmart Premium C309A All-In-One...
    HP Officejet 7410 All-in-One Blue screen error message 00000020
    I did everything you said, even the angry part lol and still nothing. Sigh...well, I've been wanting an air printer anyway :D
    Oct 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
    errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
    Aug 12, 2009 | HP LaserJet 4600 Printer
    Fax problem
    first try to make a copy and check if you get the same error message..
    if you get the same error message..try these steps..
    1)connect the printer directly to the wall outlet..and try to make a copy..if you get the same error message..then go the next step
    2)unplug the power chord from the back of the printer..press and hold OK and CANCEL buttons together..
    3)while pressing these two buttons plug in the power chord to the back of the printer..after you plug in the power chord do not release the buttons untill the screen goes blank..
    4)once the screen is blank release the buttons and turn ON the printer..
    5)wait for the printer to complete the initialization..
    6)then try to make a copy and check if it is copying successfully..
    if not machine should be replaced because scanner bulb is not getting enough power or scanner bulb is gone bad..
    please try these steps and let me if the solution has worked
    Mar 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    Automatic document feeder does not work-- does not pick up paper
    as soon as you load the original on the ADF you get the message as original loaded..check if you get this message..
    if you do not get this message..try cleaning the rollers with the lint free cloth(dry cloth)..try to make a copy..if its still the same..
    then connect the printer directly to the wall outlet..and then check..
    if its still the same then try these steps..
    1)unplug the power chord from the back of the printer..press and hold OK and CANCEL button together..
    2)while pressing these two button plug in the power chord to the back of the printer..
    3)after you plug in the power chord do not release those two buttons untill the screen goes blank..
    4)once the screen is blank release the buttons and then turn on the printer..
    5)then try to make a copy from the ADF..if its still the same..then machine should be replaced..
    let me know if this has worked..
    Mar 04, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    Scanner problem
    Hi s2009edwards, double check the USB data cable from the printer to the computer. Power off the printer. Than, unplug the data cable connected to the printer & re-connect it. Follow the data cable to the PC & unplug the cable & re-connect it. Power on the printer & wait until its done making noise. Try scanning again. If it fails to complete & you receive the same error message than buy a new printer data USB cable & replace the old one.
    http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=76&SRCCODE=WEBGOOCOMP&cm_mmc_o=7BBTkwCjC-p8ByplCjCabTwyKbywgfCjCmH4
    If the HP director software is installed (Which it should be).
    You can open HP printer software there should be an HP icon down by the clock. Right click on it once & left click open or launch. If you did not install your HP printer software suggest you do so.
    Mike
    Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Error message 83C00009 on HP L7680
    I had the same error and I just did the following and it reset the printer back to defaults and things are working once again.
    1) Turn printer off (pull power cord)
    2) Press Cancel button on top of printer
    3) Turn power back on (plug in power connector)
    4) Keep pressing Cancel button untill it looks like it reset
    Jul 30, 2008 | Office Equipment & Supplies
    HP OfficeJet 7310 All-In-One InkJet Printer Logo
    50 people viewed this question
    Seeker5211
    Seeker5211
