Question about RCA F27628 27" TV
I found chirping noise problem
I just found out the chirping sound is coming from a part with these numbers and letters on them:
PN 1536335A
DI 156334O
EXETCED2256
I looked up part number 2567005 and it doesn't look anything like the part thats making all the noise.
The problem is i don't know what the part is called, where i can get it or how to even take it off.
model number f27628
when i plugged in the tv it makes a high pitched squeal and has no other sound or picture.
    Genius:
  • RCA Master
  • 1,673 Answers
If your set is an RCA which I believe it is, you can contact RCA to find their part distributor for your area.
How did you determine that these parts are acutaly defective???
When these types of parts are defective, the cause must also be found. When replacing the parts, they will probably fail again unless the underlying cause is found. This will require the proper training, service manual, TV service experience, and the proper tools for troubleshooting.
As for changing the parts, you will require the proper tools and soldering equipment. After all the faults are found and the parts replaced, and the set is working, it is best to verify the power supply performance, the high voltage regulation, and the operating temperature of the various components effected in order to insure reliable after service operation.
Jerry G.
Posted on Apr 13, 2008
Squealing Component: PN 1536335A; D1 15303340; RXETEED2434.
You're discussing about its SMPS transformer at its main power supply section circuit; I assume. It it sounds [like a buzzer]; check for any loose fitting with its ferrite core.
May 08, 2014 | RCA F32650 32" TV
I have a 02 passat when I start If up it sound like a truck. What do you think it can be. Its not turbo it just started doing it
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make loud truck noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
My eclipse spyder 03 started making that noise like a week ago on the drivers side ? Anybody help plz!!!!
There is N-number of possibilities for the car to make whining noise or any other kind of noise.
These will help.
Thanks.
My 2004 t&c 3.8 is making a weird sound like a
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
These will help.
Thanks.
Thud in trunk at take off
There is N-number of possibilities for the car to make thud noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | 2010 Toyota Camry
Chevrolet k1500 whining noise
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
My 1997 Malibu is holding up very well. Recently, I have noticed a slight chirping noise whenever I idle (especially after starting the car) and when I accelerate to about 45 or 50. It is NOT a whine...
Remove the serpentine belt notating the direction of travel. Start the vehicle long enough to confirm the chirp is either still present or it has stopped.
If the chirp stops manually spin all the pulley by hand to see if you can duplicate the sound. If nbothing else is making noise and the belt is in good shape put the belt back so that it travels in the opposite direction. If the noise persists replace the belt. If the noise goes away see how long it lasts. I have had many that have not returned after rotating the belt.
One other thing you can try is putting a small dab of di-electric grease on the belt, with the engine off of course. Spread the dab around a little with a finger, again with the engine off. Start the vehicle, give it a couple of seconds to let the grease work around the belt. If the noise goes away replace the belt.
Nov 14, 2010 | Chevrolet Malibu Cars & Trucks
Tv is in shutdown mode caused by bad flyback transformer..
Part # 257805 or ASTI 2078......common problem, but TV
repair skill needed.........................T.
Dec 04, 2007 | RCA F32650 32" TV
High Pitched wine when turning on
yes it is worth fixing & not that serious. but please call skilled tech to fix it as high voltade is inside even it is off.if you are not a tech person.
Sep 29, 2007 | RCA F32450 32" TV
F32650 Chirping No Power On
Replace IHVT aka flyback xformer part #257805.
Nov 30, 2006 | RCA F32650 32" TV
RCA F27628 27" TV Logo
135 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
