Question about Refrigerators
Evaporator fan blade jams in ice buildup
Evap fan jams in condensate drain ice build up. takes aprox 2 weeks to freeze up. condensate drain not plugged. evap coil heater element has continuity. possible defrost timer problem ?????????? no electrical diagram handy. guessing..... please help
  • thicla01 Jun 08, 2008
    I have exactly the same problem that occurs twice. First time I've resolve it by melting the ice with a hair dryer. I'm searching for a pemanent solution.
  • 1,073 Answers
Check the defrost bimatal or defrost thermanstat it will be located on the evaperator suction line (large line) it should read continuity with the ref cold if it showes continuity then the defrost timer is the problem
Posted on Apr 13, 2008
Noisy fan in freezer stops when refrigerator doors
bad evaporator fan motor or fan motor blade or ice build up that is building up by the evap. motor or evap motor blade.
Oct 10, 2014 | Refrigerators
Drain channel freezes
I had that ice build-up problem on a side-by-side GE. In the end, it turned out to be the defrost timer. After 20 years of use, it wasn't keeping the defrost cycle ON long enough to let all the water drain out. After replacing the timer, problem disappeared.
Mar 11, 2014 | GE GBS18HBM Bottom Freezer Refrigerator
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
There is a horrible humming sound coming from the freezer. It seems to be the fan that is behind the piece of plastic in the middle of the back wall of freezer. The sticker in the freezer says MODELS...
Hard to diagnose without being there and taking it apart. Based on my experiences, I suspect the defrost drain could be restricted. The defrost water freezes in place around the fans shrould and the fan blade hits the ice buildup. If the ice builds up enough the fan blade will be stopped and possible damage the fan motor. Access fan area to inspect and defrost (hot water, hair dryer or let it stand overnight off. DC evaporator fan motor WR60X10228 est $85
Mar 09, 2010 | GE Profile Arctica Stainless Steel Top...
Recently got called out to an aeg electrolux s range.found evap drain pan in freezer to be iced up.the reported fault was fridge section too warm.found evap fan blade caught in ice, ducted air not getting...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Feb 26, 2010 | Refrigerators
Evaporator fan jams with ice buildup from drain
Could be that, or it could be the temperature sensor on the evaporator - if that goes, then as soon as the freezer starts a defrost cycle, it will think it's got the evaporator hot enough and will start cooling again.
Suggest you let the freezer thaw out then, with a voltmeter connected across the terminals on the board which connect to the sensor, turn the freezer on and see if the sensor reacts sensibly to the evaporator cooling down. It's usually done with a thermistor, but just for the moment, I can't remember whether it's usually a PTC or an NTC.
That way, if it is the sensor, you'll be spared the expense of replacing a serviceable pcb.
Apr 13, 2008 | Refrigerators
Ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Apr 02, 2008 | Refrigerators
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
Refrigerators Logo
249 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
