Question about Vacuums
I have a bissell quickwash 1950-e. I bought it Jan. 2006, and have only used it 8-10 times, I live in a very hard water area, so I though if I put some vinegar in with the cleaning solution it would get rid of any hard water deposits, unfortunatly the solution went lumpy in the tank and stoped spraying out water, I have opened it, hose clean, sprayer not blocked, x at bottom of water container when depresed water trickles out, component that opens the x when water container placed, also ran water through when run under water. Assembled altogether again, still will not spray water, suction working.
  • 1,673 Answers
Hard to say what is causing your problem, replacing the cap and insert on the water tank may help, part #2041111, even tho it may trickle out water when depressed, they can still be bad. The other thing would be the rod not relesing the water like it should. The big draw back to this model is Bissell has obsoleted all of its parts and most are no longer available. Might be wiser to buy new.
Posted on Apr 15, 2008
Instruction to put it together
Bissell has the assembly instructions in the manual for the unit. Most Bissell manuals are available here: . The direct link to the manual for 1950 series Quick Steamer is .
I hope this helps. Out of the box, the assembly is very simple. Put the handle on the lower body and secure with a Philips screw. The water tanks lift off and then get placed back on the body of the unit. (Use care when the tanks are filled with water.) See the manual for adding the bare floor tool.
Oct 15, 2015 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell quickwash 1970E for carpets/hard floors won't come on
If the burning smell was like rubber burning it is probably the belt. If you only used it a few times I suggest bringing it back to place of purchase. A belt should not go after just a few times of use. Besides if anything is burning after just a few uses I would return it.
Mar 28, 2014 | Bissell Vacuums
When i turn it on the motor makes laud noise
Mine did too. Eventually it started smoking and spat-out dust from the dead motor.
I wish I had looked at the motor and added some vaseline or something before in conked-out completely.
I think the problem was that I was not spraying water enough and so running the machine more as a dry vacuum. Maybe this allowed the motor to spin too fast and over head. Or something.
New motors are available but cost nearly as much as a second hand quicksteamer / quickwash.
Sep 12, 2011 | Bissell 1950-3 Quicksteamer Plus Vacuum
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
Jan 29, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Vacuums Logo
228 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
