Question about HP LaserJet 3055 Printer
HP Laser Jet 3055 - set on manuel
The telephone line is dedicated for the fax - but when the phone rings - it is set on manuel - if there is nobody to press fax button - the machine does not go on automatic
  • swapnil boharapi Jan 17, 2009
    i want to download the setup of this printer
    Problem Solver:
  • 13 Answers
Hit menu button, scroll it until you reach the fax setting. Select Auto fax the press ok.
Posted on Jul 09, 2012
Fax problem
Posted on Dec 27, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
My home HP laser jet 3055 machine is not connecting
Make sure that it is set to Auto Receive not Manual Receive. Also make sure the the telephone line cord is plugged into the Line jack not the Tel jack on the back of the fax machine.
Jul 19, 2012 | HP Deskjet 3050 Wireless All-in-One Inkjet...
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
How do you set up fax phone on the HP officejet 6215
hi you really have a very good choice of printers is one of the best printers from hp
inorder to set fax on ur printer you should first be sure what type of telephone line you are using
there are 2 type of line 1 dedicated -> that is directly attached for fax and has no other telephone or TAM connected if you have this line you can directly attach the phone line on the printer line 1
the other type of line is shared that means you use the same line for phone and fax in this the connection should be as :- telephone line from wall jack to the printer line 1 then from printer ext port to telephone answering machine (if any ) then from answering machine to telephone (if u have a dsl line that means u use phone and internet from the telephone line then there will be 2 lines comming out of the splitter 1 to router and other to telephone here follow the shared line connection mentioned above using the line that goes to the telephone )
now power on the printer and press the setup button (menu) now navigate to basic fax set up press ok and then go to rings to answer it should be 4 rings now go back and go to advance fax setting and then to distintive ring (DRP) select all rings and press ok now run fax test if it passes then ur fax is set up try sending fax now hope this will help you
Jul 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to connect the printer wireless
I don't think the HP 3055 has built in wireless capabilities. It does however have a built in 10/100 Base-T TCP/IP networking with 1 RJ-45 port, Hi-Speed USB 2.0 port, RJ-11 fax port, RJ-11 line-out telephone port. You should be able to connect directly into your hub or router and access the printer through a wireless router. You can get more information on set up at the link below.
May 31, 2009 | HP LaserJet 3055 All-In-One Printer
This is what is called a ring trip.
unplug your fax machine and plug in a normal phone. call the fax line. let it ring a few times. if the phone rings, but not the fax machine, check the cord of the fax machine and replace it. if the fax machine still does it, there is a short circuit somewhere in the machine. it is most likely in or around the jack that connects it to the phone cord, check for corrosion or bent contact pins.
if it rings only once or not at all, then check the phone jack for corrosion. trace it all the way back to where your phone line connects to your house. if it is still not ringing, call your telco to get them to check thier equipment.
Jan 15, 2009 | HP LaserJet 3055 All-In-One Printer
Telephone rings only twice
No. Fax machines are designed to have their own dedicated fax lines.
Some newer models, tho, allow you to set NUMBER OF RINGS.
Oct 30, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
HP laser jet 3055 not doing net work printing
Has a printer cartidge loaded but says that does not
Oct 17, 2008 | HP LaserJet 3055 All-In-One Printer
HP Office Jet 5610v All-In-One
If it is a dedicated fax line.
Then make sure auto answer is turned on.
Then go to Setup/Menu> and press the right arrow key till you see basic fax setup>
Then press Ok> Then press the right arrow key and scroll to basic fax setup> then press ok.
Then scroll to rings to answer and set it to 2.
Then press cancel and come to the main display.
Press setup/menu> and scroll to advance fax setup> and scroll to distinctive ring pattern> and select all rings.
You should be able to receive and send faxes without any problem if it is a dedicated fax line.
If it is a shared line with phone, voice mail or answering machine then you will hev to get a distinctive ring pattern from your telephone service provider.
So that it can distinguish your Fax message and voice message.
If any problem let me know.
Sep 17, 2008 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet 3055 Printer Logo
107 people viewed this question
Ben Johnson
