Question about Zyxel Prestige 660H Router
Wireless settings Could any of the experts tell me what the correct configeration settings are reqd.for this router.My ISp is TalkTalk;I have heard that they have some sort of different MTU settings than the norm. Thnks, Goofyfoot
TalkTalk technical support need to give you that info as anything you get from the 'internet' is likely to be outdated or incorrect.. or both! The details should have been in the welcome letter that's sent to every new sign-up.
Posted on Jun 20, 2008
Wireless Network Adapter Xbox 360 (SKWIFIX360): My wireless adaptor on my xbox 360 won't connect t...
1) Reset the router then the xbox.
2) If it still does not work, Change the security code for your wireless on your router. Then connect using that security code on your xbox.
Apr 28, 2010 | Microsoft Computers & Internet
Belkin FSD7632-4 v8 wireless router will not connect to my ISP
It should be ok aslong as it is in sync. Can you tell me what router settings your using for talktalk? It should be PPPoA, Vc Mux, Mtu of 1432, Idle of 0. Ip assigned by isp is yes. Also make sure your username and password is correct.The username is going to be
yourphonenumber@talktalk.net and password is as provided by talktalk. IF your getting stable sync on the belkin the distance and noise levels shouldnt be causing an issue.
Apr 16, 2010 | Belkin (F5D7230-4) Router (587009)
When i changed my isp from talktalk to sky broadband my dell 1450 adaptor can not connect even though there is a connection via ethernet cable apparently dell say it is a software problem and want to...
When it says 'Conntected: 100Mbps" on the bottom, all it's saying is that you have a physical connection between your computer and the device it's talking to.
Now one thing you need to double check is that (I assume you have a wireless router) the router or whatever device you have connecting to your ISP modem has the correct network information. For example some ISPs will give you a static IP address that you have to manually add to your router. If TalkTalk does that, and Sky doesn't, make sure your router is automatically obtaining an IP address. This should connect you to your ISP and to the internet. Then your DELL machine should get an IP address from your router and then you should be good to go.
Let me know if you need any further assistance.
Dec 10, 2009 | Dell 1450 (D1450U) Wireless Adapter
The linksys wrt54gs-uk
With a DSL modem in the US, you need to confiugre the router for PPPOE with the username/password that was provided to you by your ISP. If you can't remember the name or password, contact your ISP
May 31, 2009 | Linksys Wireless-G Broadband Router
Can't connect to wireless xbox360 live
You need to contact your ISP. I have never heard of TalkTalk, but if its a DNS problem, its your ISP.
Dec 29, 2008 | Microsoft Xbox 360 Console
ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Sep 23, 2008 | Zyxel Prestige 660HW Wireless Router...
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Changed isp but cant get connected on my dynamode wireless router only on router supplied, isp now talktalk
2 problems 1.pressed reset on btm of router
2.password was case sensitive
everything appears to be ok now.
Jul 12, 2008 | Computers & Internet
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Zyxel Prestige 660H Router Logo
185 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
