Question about Olevia LT42HVi 42 in. LCD Television
Olevia 42" Sometimes our Olevia LCD TV doesnt turn on. We have to switch off the power control on the tv to reset it, then try again with the remote. After a few times it usually turns on, but sometimes it wont turn on for a whole day. Any solutions?
  • 3 more comments
  • givemhall Jun 19, 2008
    37"
    We are selling our house. We moved the 37" from one room to another for a showing and then moved it back into our bedroom several hours later. IT WILL NOT TURN ON. We tried the remote and the off/on on the television set. We unplugged it and plugged it back in. It's the television. The converter box seems to be working, but the tv just sits there. This tv isn't even a year old???
  • SPGallo Jul 02, 2008
    We have the 42 inch Olevia. It won't turn on! If you hit the button with the blue light, the TV should come on and it does not. The blue light flashes and the TV won't come on. The TV is only 4 months old. Help, does anyone know what this is????
    Thanks.
  • Anonymous Aug 25, 2008
    no blue light and does not turn on
  • Skuz Jan 28, 2009
    My 40" Sony Bravia which I've had now for 2 years has been working perfectly. It's never been moved or tampered with in any way, and yet recently I have to switch it on with the remote twice or three times before it will turn on. It keeps turning itself off before any picture apprears, right after I switch it on.
    This has only happened recently, and like I said it hasn't moved from its spot in 2 years, so no buttons have been pushed or damaged. This morning I tried three times before the picture came up, and it so far always stays on once it's switched on. Please help!!!!
  • kdneena4 May 07, 2009
    my tv won't come on
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Posted on Apr 23, 2009
@givemhall: I had this happen to my 42" after I moved. It turns out that when we were carrying the TV, the power button got pressed down too hard (it's right near where you would put your hand to lift the set) and it was stuck in the ON position. We took the TV apart and fixed the switch, then the TV worked like a charm. It's about an 45 minutes worth of tear-down, but we were ecstatic when it came back to life. Hope this helps you!
Posted on Aug 11, 2008
    Problem Solver:
  • 7 Answers
It's the main switch turned on,unplug and replug power cord
Posted on Jun 21, 2008
Olevia 42" tv no sound no power sometimes
Start with having the power supply capacitors checked, common problem on older Olevia sets!
Dec 01, 2012 | Olevia LT42HVi 42 in. LCD Television
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
My RC LTL remote control has quit working.
Try website like Remotes.com to buy an exact original or compatible remote.
May 26, 2010 | Olevia 742I 42 in. LCD TV
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Problem for Sony Grand WEGA KF-42SX300 42 in. LCD TV Only goes from red to amber on led
hello try a factory reset. turn on the tv while holding the reset button on the remote control, press the power button on the tv, the tv will turn itself off and back on again release the reset button
shaun
Nov 02, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
I need the Olevia 427-S11 TV Remote Control Codes , please.
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
Jul 06, 2009 | Olevia LT32HVM 32 in. LCD Television
I have an Olevia 542-B11 TV with remote control. I have Directv and always had to use (2) remote controls. My dog chewed my Olevia remote control, now I can't turn the TV on or off, adjust volume, switch...
its hard to find a remote that will work an olevia , since this brand is new and alot of manf. that make universal remotes have not updated there system..
This company called Amergence Technology sells the Olevia Remote and will control any olevia television.
Contact them at 866-965-3842 (just ask to purchase a remote)
Jun 29, 2009 | Olevia LT42HVi 42 in. LCD Television
Program code for olevia 37 to direct tv remote
Mar 15, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Remote control codes
Juni,
You'll have to look it up by the remote you're using... Then by the brand of Tv you're trying to control.. try here..
http://www.remotecodelist.com/remotes/
Bill
Dec 27, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
1,154 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
