Back to:
Tags:
Jenn-Air JGS8750 Gas Kitchen Range
Igniter continuously clicks (by 2 users)
posted by pillowhugger on Apr 13, 2008
Brand new - day 2 of use - Once the burners have flames present, the igniter continues to click. Have to turn off the burner. This happens with all the burners.
What can I do?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by lftmstr1245r, posted on May 16, 2008
Best Solution
posted on May 22, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had this problem. It was caused by the burner "thinking" the flame had turned off--it was clicking because it was sparking to re-start the flame from the gas. I was able to fix it by tightening a flat, thin nut at the top of the burner.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Igniter continuously clicks:
I don't want to Accept this solution
Solution #2
posted on Jul 09, 2008
Not Rated (0)
edh6
Rating: 0%, 0 votes
I've had this same problem for 2 yrs. Know one yet has been able to fix it. Now Jennair wants to charge labor fees, even though this has been an ongoing problem. 3,000.00 for a stove and now I'm stuck paying for labor cause it wasn't put together right in the first place....wow.
Thank You!
Can you Help with these Kitchen Ranges problems?
When we run the oven self-clean, the oven interior...
When I press "clean" key, it beeps twice, but...
Just came home and I think the power went out while I was...
other burners make a clicking sound when only one burner...
one burner is not working - ignition does not spark good...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
